[Other] Modify mesh runtime
Old   June 21, 2010, 08:02
Default Modify mesh runtime
Daniele
Daniele111 is on a distinguished road
Hi
I'm simulating a evolutive case. My initial domain is a rectangle 2d and the shape of the bottom is a gaussian. At each temporal step the bottom modify its shape, How can I modify the mesh quickly at each time step?
Thanks
Daniele111 is offline   Reply With Quote
Old   June 21, 2010, 09:11
Sandeep Menon
deepsterblue will become famous soon enough
Simple. Use the mesh-motion solver to move points at each time step. Take a look at icoDyMFoam and its multiple variants.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   June 21, 2010, 09:54
Daniele
thanks
Uhm the coordinates of new point are calculated with matlab. I can use icoDyMFoam?
Old   June 21, 2010, 09:59
Sandeep Menon
I don't see why not. I would write a function in C++ that replicates the matlab code to define boundary point-positions, and pass that into the mesh-motion solver to let it deal with internal ones. There's a ton of code-snippets in the forum that deal with this situation.
Sandeep Menon
Old   June 21, 2010, 19:37
Daniele
I can use it with simpleFoam?
Old   June 21, 2010, 19:55
Daniele
I don't understand well how work it. In my problem matlab simulate a process and inside it (for cycle) I call OpenFoam to calculate shear stress, the new shape of the bottom is result of matlab script, I would modify old vertex mesh into the new one, and recalculate the new shear stress with openfoam etc...
Old   October 11, 2010, 04:29
Daniele
hi
I'm using simpleFoam for my simulation couple with a matlab script. I do a simulation with openfoam and I use its result for matlab script that update the geometry. How can I modify my mesh without remeshing to start a new simulation? I use a fluent mesh. It is a evolutive simulation coupled with matlab, and during the simulation change only the bottom shape.
Thanks
Old   October 12, 2010, 14:18
Sina
shajitah is on a distinguished road
Dear Daniele,
As far as I've realized, you've written a script in Linux which calls OpenFOAM. I'm gonna do a similar job. Actually, I'm supposed to write an algorithm in C++ or Matlab which one part of it deals with CFD calculations in which it needs to call OpenFOAM. I was wondering if you could please provide me a sample code/script (in any language) which calls OpenFOAM or a tutorial which might help me sort out the way of calling OpenFOAM.
Cheers,
Sina
shajitah is offline   Reply With Quote
Old   December 19, 2010, 15:43
Daniele
Hi
What kind of command i must use to update my geometry. My situation is this:
1) Matlab script -> new bottom geometry
2) Update OpenFoam mesh with new bottom
3)OpenFoam simulation-> result go to matlab
loop
So Can i update OpenFoam mesh? Matlab script give me new vertex position of the mesh bottom.
Help me!
Daniele
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Modify my mesh runtime Daniele111 OpenFOAM Running, Solving & CFD 0 October 9, 2010 07:23
