[Technical] BlockMesh not making arcs
Old   July 6, 2010, 07:54
Default BlockMesh not making arcs
G B
Disco_Caine is on a distinguished road
Hi, i've been reading the userguide on how to do simple arcs (and it seems simple enough) but for some reason, it's not working for me.
Here is my mesh:
vertices
(0 -1.35 0) //0
(10.235 -6.835 0) //1
(10.235 6.835 0) //2
(0 1.35 0) //3
(0 -1.35 4.45) //4
(10.235 -6.835 4.45) //5
(10.235 6.835 4.45) //6
(0 1.35 4.45) //7
blocks
hex (0 1 2 3 4 5 6 7) (10 1 100) simpleGrading (1 1 10)
edges
arc 1 2 (11.5 0.0 0.0)
arc 5 6 (11.5 0.0 4.45)
patches
patch walls
(0 4 7 3)
(0 1 5 4)
(1 2 6 5)
(2 3 7 6)
(3 2 1 0)
(4 5 6 7)
mergePatchPairs
As you can see, the edge is defined accordingly. But when i create my mesh and use paraview I get a straight line instead of an arc. I assume it's something quite simple (as my past enquiries have turned out to be). But i am stumped here.
Thanks in advance!
GB
Disco_Caine is offline   Reply With Quote
Old   July 6, 2010, 10:03
G B
Update:
FIXED! I ended up copying the blockmeshdict from the stress analysis tutorial and modifying the vertex and the arcs accordingly and it worked. Doing a line by line comparison it is exactly the same. I dont know what happened. So, for anyoe out there having trouble making arcs, just copy the blockmeshdict from the stress analysis tutorial, and modify accordingly. Best of luck!
Old   July 6, 2010, 10:09
Stefan Herbert
herbert is on a distinguished road
Just for note:
the problem here was, that an arc was defined on an edge (1 2) with only one single cell. To create arcs, of course, you need some more cells along it.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   July 6, 2010, 10:16
G B
Ofcourse, that was it. How embarassing. I should bite my tongue (or fingers) before i post. I thought i had set 10 cells for my y axis. And the tutorial case file has that and that is why it worked. Thank you for pointing that out to me. I can't believe it.
Thank you again, Stefan.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
