[snappyHexMesh] SnappyHexMesh hangs during refinement
Old   December 8, 2009, 14:51
Default SnappyHexMesh hangs during refinement
Simon Rees
sjrees is on a distinguished road
I am trying to mesh a geometry consisting of a single background mesh box created with blockMesh and a single STL surface that will become the bottom of the box. This is a rough surface with a number of building outlines protruding into the flow.
I can get the mesh to refine to the first level but snappyHexMesh always hangs when trying to refine to the second level. I can an error:
>Surface refinement iteration 2
>[5] meshRefinement::checkData() : Found 0 duplicate pairs of faces.
>[7] meshRefinement::checkData() : Found 0 duplicate pairs of faces.
>Marked for refinement due to surface intersection : 9 cells.
The application is running flat out continually (100% cpu shown using top) from this point. Only a modest amount of memory is being used so I know it is not swapping at this point.
Any ideas please?
sjrees is offline   Reply With Quote
Old   September 11, 2010, 10:43
ziad is on a distinguished road
Same problem here.
Meshing worked fine before then I shifted the outlet plane further downstream (flow around a 3D rectangular building structure) and sHM just hangs after the 4th mesh refinement iteration 2. This is the last "mesh refinement iteration 2" since I am running 4 threads in parallel. The other 3 complete no problem. Shifting the outlet domain further downstream merely adds a rectangular chunk of structured hex on the blockMesh side. sHM doesn't even do anything down there.
Tried refining/coarsening around the point where it was hanging but no luck.
Output from debug level 1 is attached and shows where sHM is hanging.
ziad is offline   Reply With Quote
Old   September 11, 2010, 12:29
Default obviously a snappyHexMesh bug
As posted previously, refining or coarsening the area of the problem did not help. Also tried playing with the mesh quality parameters such as allowing more or less concavity, using more smoothing iterations, etc. No luck there either.
Here's what worked: pushing the outlet plane of the domain a few more units downstream! Weird but consistent with the source of the problem. sHM started hanging when I initially pushed the outlet plane downstream.
Definitely a (rather exotic) bug!
Old   September 11, 2010, 17:05
Retired Super Moderator
Bruno Santos
Greetings Ziad,
Could you report your findings about this bug here: http://www.openfoam.com/bugs/
By the way, are you using the latest OpenFOAM 1.7.x version? If not, perhaps this bug might already have been fixed.
Best regards,
Bruno
Old   September 11, 2010, 21:59
Hi Bruno,
I'll report the bug.
Meanwhile I am using 1.7.0. Not planning to upgrade just for this though.
Cheers,
Ziad
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
