[Other] movingCone with sliding boundary
Old   November 18, 2010, 22:52
Default movingCone with sliding boundary
Daniel
dancfd is on a distinguished road
Hello all,
I am conducting a simulation with an oscillating airfoil, and I would like to make the grid points on the outlet of the C-grid move up/down in concert with the trailing edge of the oscillating airfoil, to improve mesh quality. Essentially, I am trying to implement the same feature as the movingCone tutorial, where the points above the cone are stationary relative to the cone during the cone motion. If that was my simulation, it would be as if the cone moved, but the grid points above the cone remained stationary, greatly distorting the mesh.
Thanks in advance,
Dan
dancfd is offline   Reply With Quote
Old   December 18, 2010, 10:30
Usit McCarra
McCarra is on a distinguished road
Might be for the boundary conditions of the upper part of the domain in 0/cellMotionUx and 0/pointMotionUx. It is "slip".
Best
McCarra is offline   Reply With Quote
Old   December 19, 2010, 18:47
Daniel
Thanks Jose, it worked great!
Dan
Old   December 20, 2010, 03:24
Usit McCarra
Hey Dan!
I'm trying to do the same (in the rotating square), but just the upper and lower boundaries slip. How can I make the left and right boundaries slip also? I think that's what you did in your case and worked!
Regards
Old   December 20, 2010, 17:08
Daniel
Hi Jose,
Are you saying that you applied the same "slip" bc to all four sides but it only worked on two sides? I'm afraid I don't know why that would happen. When I say that it worked for me, I mean that the points are moving in the far field at the boundary, but I still have mesh quality issues with the rotating body at the body boundary. No solution yet, unfortunately.
Dan
Old   July 30, 2013, 09:29
Default moving cone problem (pimpleDyMFoam)
hhh
kunar
hhh is on a distinguished road
Hai Dan,
1.) In moving cone problem (pimpleDyMFoam), Is there any possibility for continuous translation motion? (ie) left to right
2.) Is there any mathematical equation for that? How I can Proceed, kindly guide me
kunar
hhh is offline   Reply With Quote
Old   July 30, 2013, 22:05
Daniel
Hello Kumar,
Unfortunately I was not able to make this work. Good luck, though.
Dan
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
