cgnsToFoam problems with "QUAD_4" cells
Hello everyone,
I performed cgnsToFoam but got some warnings: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * Create time --> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 20 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 21 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 0, section 22 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 117 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 118 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 119 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 1, section 120 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 1 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 2 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 2, section 3 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 281 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 282 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 283 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 284 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 285 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 286 has no OpenFOAM equivalence - skipping --> FOAM Warning : Cell type "QUAD_4" found in zone 3, section 287 has no OpenFOAM equivalence - skipping --> FOAM Warning : The BC "DT to RU Side 1" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "DT to RU Side 2" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "RU to SVWG Side 1" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "SVWG to SC Side 2" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "NOSE_LOWER Side 1" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "NOSE_LOWER Side 2" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "NOSE_UPPER Side 1" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "NOSE_UPPER Side 2" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "RU to SVWG Side 2" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type --> FOAM Warning : The BC "SVWG to SC Side 1" is defined with a type BCTypeNull. It will be mapped to Foam's wallFunction type Output of mesh and boundary conditions Now,I want to show this "QUAD_4" cells in ParaView to localize them. Does anyone know, how I can do that?Additionally I don't know, how I can allocate the information "zone 0, section 20" to specific points? Thanks in advance. Markus |
I got it!
The adfviewer visualises these '"QUAD_4"-Cells. |
