[snappyHexMesh] snappyHexMesh removes wrong cells |
October 26, 2015, 07:48 |
Rep Power: 10 |
Hello!
I probably have a simple problem with snappyHexMesh that could be solve with ease, but i tried it and looked in this forum for a similar problem but i didn't find it. Well, i have created a .stl object with 3dsMax, a prism that pretends to be a buiding. Here you have its axis view and size in paraView. buildingxy.jpgbuildingyz.jpg Then i built up a rectangular mesh by editing pitzdaily tutorial. I had no problems with the mesh. Then i edited the snappyHexMechDict and i tried to remove the cells from the place where the object must be. However, the result of snappyHexMesh was that it had remove the external cells to the object and i had leave the internal cells, the opposite that i wanted. I thought that the problem would be the locationInMesh, but i tried with different ones (all of them inside the building), even different decimals (i thought that i could be on a face) but it always happens the same. initialmeshxy.jpg initialmeshyz.jpg finalmeshyz.jpg If you need, i can post my blockMeshDict and my snappyHexMeshDict too. I hope you could help me. I would be very grateful. |
October 26, 2015, 07:55 |
snappyHexMesh removes wrong cells (2)
Rep Power: 10 |
October 26, 2015, 13:45 |
DanielP
Rep Power: 11 |
Hello Pela,
The locationInMesh must in the zone of the mesh you wish to keep. In your case, you must place the point outside the STL, but inside your initial mesh. Daniel |
October 27, 2015, 06:39 |
Rep Power: 10 |
mesh 3d, snappyhexmesh |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
