-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   Cyclic mesh for fully-developed profile (http://www.cfd-online.com/Forums/openfoam-meshing/97270-cyclic-mesh-fully-developed-profile.html)
fferroni February 13, 2012 17:01
Hello
I am trying to find the fully developed velocity profile in a straight duct.
Rather than compute a 3D duct, and look at its profile towards the end, I would like to apply periodic boundary conditions to make it more efficient. I have never done this on openFOAM and would like some help.
I have a inlet and an outlet boundary. So:
boundary
inlet
type cyclic;
neighbourPatch outlet;
faces
(0 4 7 3)
outlet
type cyclic;
neighbourPatch inlet;
faces
(2 6 5 1)
However, now I am wondering what kind of boundary field definitions I need.
Previously I had zeroGradient or fixedValue fields (depends on variable) for both the inlet and outlet. What do I need to set for the periodic case?
Thank you very much.
Kindest Regards,
F
stevenvanharen February 14, 2012 07:17
Take a look at the channelFoam tutorial. This will help you I think.
Please keep in mind that the pressure field is never periodic. Therefore you will have to split the pressure field in a periodic part and a pressure drop. This can be seen in the channelFoam solver.
fferroni February 14, 2012 08:27
I see..
So, it means that I need to modify my solver?
Looking at channelFoam.c, I would need to slightly change the first part before the PISO loop and add the section correcting the driving force for a constant mass flow rate. I would not need to change any field definitions, apart from creating createGradP.H, is that correct?
In the first section, what is "sgsModel->correct(); " ?
Kindest regards,
Francesco
stevenvanharen February 14, 2012 08:40
That you can do indeed, or you can use a jumpcyclic. This has different names for different OF versions I think. Browse around the OF source to see the difference.
src finiteVolume fields fvPatchFields
The same holds for sgsModel->correct(); Browse around the turbulence models to see what it does.
src turbulenceModels
fferroni February 15, 2012 03:58
Hmm, I don't quite understand how jumpCyclic works (especially trying to read the source code).. Is there a tutorial on how to use it?
There is a fan tutorial in OF that apparently uses it but I'm not sure how that is relevant to what I'm trying to do...
Kind Regards,
F
zxj160 July 11, 2012 10:49
Originally Posted by fferroni (Post 344209)
Hello
boundary
inlet
type cyclic;
faces
(0 4 7 3)
outlet
type cyclic;
faces
(2 6 5 1)
Kindest Regards,
F
Dear F,
I also met the same problem that I want to set zeroGradient or fixedValue fields (depends on variable) for both the cyclic inlet and outlet. Did you find a way to achieve it?
My best regards,
Jian
