[snappyHexMesh] motorbike tutorial error in snappy hex |
March 7, 2012, 09:33 |
Mihai Pruna
Rep Power: 16 |
I tried to run the tutorial using allrun.
i get the following error: Running snappyHexMesh on /opt/OpenFOAM/OpenFOAM-2.0.x/tutorials/incompressible/simpleFoam/motorBike /opt/OpenFOAM/OpenFOAM-2.0.x/bin/tools/RunFunctions: line 37: 5698 Killed $APP_RUN $* > log.$APP_NAME 2>&1 I attempted the STL file cleanup from here and replaced the file with the new stl file, still getting the error Please help. thank you! |
March 7, 2012, 10:43 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Mihai,
You've skipped the very first step from the tutorials guide: http://www.openfoam.org/docs/user/tutorials.php Quote:
Best regards, Bruno
March 7, 2012, 13:36 |
Mihai Pruna
Rep Power: 16 |
oops thanks, I forgot about that step
March 7, 2012, 20:29 |
Mihai Pruna
Rep Power: 16 |
ok, I copied to $FOAM_RUN, same error. Even tried a different stl file.
I'm using the OpenFOAM packaged with GeekoCFD
Mihai Pruna's Bio |
March 8, 2012, 04:31 |
Bruno Santos
Rep Power: 128 |
Hi Mihai,
Mmm... OK, try getting the latest one from the snapshot link at the top left on this page: http://repo.or.cz/w/OpenFOAM-2.0.x.g...Foam/motorBike By the way, does the file "log.snappyHexMesh" get created? If so, what's the error message it shows inside it? If this also fails, perhaps you've got to complain to Alberto Wow, GeckoCFD 3.0 is now available as well: http://albertopassalacqua.com/?p=1234 Best regards, Bruno
March 8, 2012, 15:27 |
Mihai Pruna
Rep Power: 16 |
I did a fresh OF install on Ubuntu and it works now.
Thanks
Mihai Pruna's Bio |
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) | robingilbert | OpenFOAM Meshing & Mesh Conversion | 28 | November 23, 2023 06:32 |
[snappyHexMesh] Snappy Hex Mesh External Domain | willindsey | OpenFOAM Meshing & Mesh Conversion | 2 | June 9, 2017 22:03 |
pimpleDyMFoam - rho not found | maasyraf3 | OpenFOAM Running, Solving & CFD | 10 | June 5, 2017 13:05 |
[snappyHexMesh] Snappy Hex Mesh Generation: error preventing the .eMesh file generation. | Mariana Garcia | OpenFOAM Meshing & Mesh Conversion | 1 | January 7, 2016 04:24 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 00:14 |
