Home > Forums > OpenFOAM Meshing & Mesh Conversion
Complementary solid-gas meshes
Old   March 12, 2012, 05:55
Default Complementary solid-gas meshes
anon_a is on a distinguished road
Hello again
I have a non-trivial geometry and would like to use chtMultiRegionFoam to model heat transfer from a nitrogen ambient. How can I obtain the two perfectly matching meshes (nitrogen and solid) if I have the solid geometry? I guess they need to be entirely complementary and to have matching meshes, or am I wrong?
anon_a is offline   Reply With Quote
Old   March 14, 2012, 04:56
I have been following this post:
http://www.cfd-online.com/Forums/ope...le-meshes.html
I know that's probably not the right place to post this but please bear with me. SALOME does not let me mesh the damn thing. Even when I choose a very coarse discretization, I keep getting "Memory allocation problem". Even for a very simple geometry, such as a simple cube. It only works randomly once every 200 trials or something (I haven't found the bug pattern yet).
Does anyone know how to solve this?
Old   March 15, 2012, 16:02
Forget about the error. The 64bit version was installed on a 32bit SUSE.
That's what happens when they don't let you set up your own machine.
SALOME worked as written in the previous post and it rocks.
Thread Tools
Trackbacks are On
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 16:53
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
