[blockMesh] subtract volume in blockMesh
Old   April 13, 2012, 15:21
Question subtract volume in blockMesh
Adam
Smed is on a distinguished road
I am wondering what is the best way to subtract volume from a block in blockMesh. I have attached a drawing of what I want to do. I have an 8 point block, but I want to remove another 8 point block from somewhere in the middle of it. Is there an easy way to do this, or do I need to create 4 separate blocks which surround the empty space and then merge the patches like i've drawn at the bottom of my attachment?
Smed is offline   Reply With Quote
Old   April 13, 2012, 15:55
Retired Super Moderator
Bruno Santos
Greetings Adam,
If you have properly defined all of the cells, then you can use setSet to:
  • select the cells to be removed (which means that they must already exist... ironic, I know);
  • then invert the selection;
  • then use subsetMesh to save only the last selection of cells.
How to use setSet:
Best regards,
Bruno
Old   April 16, 2012, 08:57
Adam
Bruno,
This worked great, thanks! I ended up following the damBreakWithObstacle tutorial ($FOAM_TUTORIALS/multiphase/interDyMFoam/ras/damBreakWithObstacle), for anyone else who's interested.
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
