OpenFOAM Patched Version 1.5 via git Repository
OpenCFD releases patched version of 1.5 via git repository.
Patched sources for the current version are now available that include fixes for all submitted bugs. The sources can be obtained using the git open source version control system that is commonly available on Linux distributions. Note that this version is sources only so will require full compilation. The bug-fix/patched version repository is available at git://repo.or.cz/OpenFOAM-1.5.x.git. The repository can be obtained using the command: git clone git://repo.or.cz/OpenFOAM-1.5.x.git This will create an OpenFOAM-1.5.x directory that the user can subsequently update to the latest published copy using git pull git://repo.or.cz/OpenFOAM-1.5.x.git This source tree can then be compiled in the usual way, please follow the instructions in the documentation. |
