Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
GPU Linear Solvers for OpenFOAM
Like Tree5Likes
Old   April 23, 2011, 19:16
Default GPU Linear Solvers for OpenFOAM
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
ofgpu is a free GPL library from Symscape that provides GPU linear solvers for OpenFOAM®. The experimental library targets NVIDIA CUDA devices on Windows, Linux, and (untested) Mac OS X. It uses the Cusp library's Krylov solvers to produce equivalent GPU (CUDA-based) versions of the standard OpenFOAM linear solvers:
  • PCG - Preconditioned conjugate gradient solver for symmetric matrices (e.g., p)
  • PBiCG - Preconditioned biconjugate gradient solver for asymmetric matrices (e.g., Ux, k)
ofgpu also has support for the OpenFOAM preconditioners:
  • no
  • diagonal
For more details see "GPU Linear Solver Library for OpenFOAM".
OpenFOAM is a registered trademark of OpenCFD and is unaffiliated with Symscape.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   May 2, 2011, 04:04
Bernhard
Bernhard is on a distinguished road
Hi Richard,
Thanks for the nice work. I was able to compile OpenFOAM-1.7.x and use your plugin on the GPU. Your testcase also worked nicely.
Some comments that may help other people that are installing this library.
- I set gcc 4.3 as a compiler in ofgpu for C, and g++ (this is standard) for C++.
- Other people in my department are already using CUDA, but not Cusp and Thrust, I downloaded Cusp and Thrust code-packages to /ofgpu/src
- To patch, I used patch -p0 < file.patch
To compile OpenFOAM 1.7.x with the gpu library, I did the following
- chmod 770 src/gpu/Allwmake
- touch src/gpu/gpuless/Make/options (this file was missing)
- I think there is a mistake in src/gpu/cuda/Make/options, I used LIB = $(FOAM_LIBBIN)/cuda/libgpu there
- In OF/lib I made a symbolic link named libofgpu.so to the library in the ofgpu directory
You can check the activity of your graphical card with nvidia-smi -a -l
For the standard GPU in my machine with nice CPUs, this test case (pitzDaily) there was only slow down of course.
Richard, thanks for the nice work, I read on the website you're working on implementing additional preconditioners. I'm very of course very interested in those. Keep up the good work!
Best regards,
Bernhard
Bernhard is offline   Reply With Quote
Old   May 2, 2011, 04:46
Pablo
pablodecastillo is on a distinguished road
Is It necessary to compile all openFoam, or just a library??
Pablo
pablodecastillo is offline   Reply With Quote
Old   May 2, 2011, 05:51
Bernhard
In principle you only have to recompile those parts of the code that are affected by the patch I suppose. Since I have been working with 1.7.1, and this library was designed for 1.7.x, I decided to take the save route and download and compile 1.7.x separate from my other installation. It would be worth trying it on your existing compiled OpenFOAM version.
Old   May 2, 2011, 09:13
Default Thanks for the feedback
gocarts's Avatar
Richard Smith
Thanks for the feedback Bernard.
You raised some good points:
I'll update the source code patch shortly to fix these 2 problems.
I think these 2 issues are caused because you are missing one or more of the following:
  • CMAKE_INSTALL_PREFIX variable as <ofgpu-root>/install - while configuring ofgpu with ccmake
  • ln -s <ofgpu-root>/install/release/lib <ofgpu-root>/install/lib - after 'make install'
  • export CUDA_ARCH_PATH=<ofgpu-root> - prior to building and running OpenFOAM
I've edited the build description to make this clearer at: http://www.symscape.com/gpu-openfoam
Old   October 17, 2011, 08:52
Default Casting problem
Ahmad Lashgar
ahmadlashgar is on a distinguished road
I've successfully compiled ofgpu.During compilation of OpenFOAM there is casting problem between ofgpu::index and Foam::label.
I can solve the problem by manually cast-forcing. But, is there any quick solution?
Thanks.
The related error is shown here:
PBiCGgpu.C:103: error: no matching function for call to ofgpu::SparseMatrixArgs::SparseMatrixArgs(const char*, Foam::label, Foam::label, ofgpu::index*, ofgpu::index*, ofgpu::index*, ofgpu::real*, ofgpu::real*, ofgpu::index*, ofgpu::index*, ofgpu::real*, ofgpu::real*, ofgpu::real*, int, ofgpu::real, ofgpu::real, ofgpu::real, ofgpu::real, Foam::label, bool&)
/home/tesla/OpenFOAM/ofgpu/src/ofgpu/sparsematrixargs.h:46: note: candidates are: ofgpu::SparseMatrixArgs::SparseMatrixArgs(const char*, ofgpu::index, ofgpu::index, const ofgpu::index*, const ofgpu::index*, const ofgpu::index*, const ofgpu::real*, const ofgpu::real*, const ofgpu::index*, const ofgpu::index*, const ofgpu::real*, ofgpu::real*, const ofgpu::real*, ofgpu::index, ofgpu::real, ofgpu::real, ofgpu::real&, ofgpu::real&, ofgpu::index&, bool&)
/home/tesla/OpenFOAM/ofgpu/src/ofgpu/sparsematrixargs.h:24: note: ofgpu::SparseMatrixArgs::SparseMatrixArgs(const ofgpu::SparseMatrixArgs&)
make: *** [Make/linux64GccDPOpt/PBiCGgpu.o] Error 1
Diego Alex Mayer likes this.
ahmadlashgar is offline   Reply With Quote
Old   October 17, 2011, 09:36
Default Foam::label as long, why?
gocarts's Avatar
Richard Smith
So I guess on your system (Linux?) you have Foam::label defined as a long?
That would result from defining 'FOAM_LABEL_64' for label.H
Is this the case?
Do you really need access to integers larger than 2,000,000,000? Do you want to solve for more than 2 Billion cells/faces/nodes?
So my first suggestion is that if you don't need to define FOAM_LABEL_64 then don't (you save memory too) and recompile OpenFOAM.
Second option if you do want to keep FOAM_LABEL_64 then try changing the definition of ofgpu::index to long in index.h. This will cost you scarce GPU memory if it works.
Old   October 17, 2011, 10:02
Default The patch file issues
Ahmad Lashgar
Dear gocarts,
Thanks for the quick reply.
You are right, FOAM_LABEL_64 is defined automatically because the operating system is "Ubuntu-Desktop-10.10 64-bit". I've solved the problem with casting.
The compilation proceeds and fails upon Allmake in "/home/tesla/OpenFOAM/OpenFOAM-1.7.1/applications/solvers/multiphase/compressibleInterFoam" directory.
Main errors are:
compressibleInterFoam.C:43:22: error: RASModel.H: No such file or directory
compressibleInterFoam.C:44:22: error: LESModel.H: No such file or directory
followed by:
compressibleInterFoam.C:51: error: "incompressible" has not been declared
compressibleInterFoam.C:52: error: "incompressible" has not been declared
This is caused by the patch file which makes some changes and adds "#include RASModel.H" and "#include LESModel.H" lines to compressibleInterFoam.C. However, these files are not exists in compressibleInterFoam directory.
These files are in the following path:
./src/turbulenceModels/incompressible/RAS/RASModel/RASModel.
./src/turbulenceModels/compressible/RAS/RASModel/RASModel.H
Should I make a soft link? or I have missed something in earlier stages
Thanks.
System: Ubuntu-10.10, OpenFOAM-1.7.1, CUDA 3.1 and GCC 4.4
Old   October 17, 2011, 10:14
Default What about ofgpu 0.2?
gocarts's Avatar
Richard Smith
Wouldn't you prefer to build the latest version of ofgpu 0.2 with OpenFOAM 2.0.x? http://www.symscape.com/gpu-0-2-openfoam
By the looks of your errors it seems that your build may have failed to create the turbulence libraries. The missing includes should be in:
./src/turbulenceModels/incompressible/lnInclude
./src/turbulenceModels/compressible/lnInclude
Old   October 17, 2011, 10:25
Default Ofgpu_0.2
Ahmad Lashgar
Happy to see OFGPU 0.2 is compatible with CUDA 4.0.
I have downgraded thrust, cusp and cuda to make the required compatibility.
I will test OFGPU 0.2 soon,
Thank you
Old   October 17, 2011, 10:32
Default Don't define FOAM_LABEL_64
  #11
gocarts's Avatar
Richard Smith
Just to follow up on:
I can't see where this is defined by default. It's not about whether you are compiling 64-bit, it relates to the size of integers. If you can find where it's defined I suggest removing it. Most likely it's somewhere in:
./wmake/rules/<platform>/c++
Edit: Should be FOAM_LABEL64 not FOAM_LABEL_64
Old   October 17, 2011, 10:38
Default label.H
  #12
Ahmad Lashgar
Actually It is not defined! Following commands show that FOAM_LABEL_64 does not exist but FOAM_LABEL64 is used in label.H and uLabel.H
root@gpu30:~/OpenFOAM# grep -r ./ -e FOAM_LABEL_64
root@gpu30:~/OpenFOAM# grep -r ./ -e FOAM_LABEL64
./OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/label.H:#if FOAM_LABEL64
./OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/uLabel.H:#if FOAM_LABEL64
./OpenFOAM-1.7.1/src/OpenFOAM/primitives/ints/label/label.H:#if FOAM_LABEL64
./OpenFOAM-1.7.1/src/OpenFOAM/primitives/ints/uLabel/uLabel.H:#if FOAM_LABEL64
So the label type is int not long.
Old   October 17, 2011, 10:51
Default Double precision vs single precision
  #13
gocarts's Avatar
Richard Smith
I think then your problems are two fold:
  • You need to patch the exact version of OpenFOAM 1.7.x (not 1.7.1) specified in the instructions at: http://www.symscape.com/gpu-openfoam
  • I guess you are trying to compile in double precision, whereas ofgpu assumes single precision
I haven't tried double precision, so I can't help you with that, though someone in the comments for the instructions mentioned it.
Old   October 17, 2011, 11:03
Default How to run the sample?
  #14
Ahmad Lashgar
OK. I think the OpenFOAM is now compiled successfully.
I'm new in OpenFOAM. How can run "pitzDailyGpu" sample?
I've extracted the archive, now there exist 3 folders:
0 constant system
Thanks.
Old   October 21, 2011, 10:51
Default OF compilation problems
  #15
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I still have a problem with the compiling
I use GCC 4.4, thrust 1.4, cusp 0.2, OF 2.0.x (Oct 21st) and applied the patch. Everything else before of-gpu is compiled without errors.
After applying the patch, I can't compile OF 2.0.x anymore. I get problems.
There must be a problem with the include or something because it is missing basically all the files for include like the following
Making dependency list for source file pimpleFoam.C
could not open file fvCFD.H for source file pimpleFoam.C
Making dependency list for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file fvCFD.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file dynamicFvMesh.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file volFieldsFwd.H for source file pimpleFoam.C
could not open file surfaceFieldsFwd.H for source file pimpleFoam.C
could not open file fvMatricesFwd.H for source file pimpleFoam.C
could not open file pimpleControl.H for source file pimpleFoam.C
could not open file createPhi.H for source file pimpleFoam.C
could not open file initContinuityErrs.H for source file pimpleFoam.C
could not open file readTimeControls.H for source file pimpleFoam.C
could not open file CourantNo.H for source file pimpleFoam.C
could not open file setDeltaT.H for source file pimpleFoam.C
could not open file continuityErrs.H for source file pimpleFoam.C
could not open file volFieldsFwd.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file surfaceFieldsFwd.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file fvMatricesFwd.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file basicKinematicCollidingCloud.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file createDynamicFvMesh.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file readGravitationalAcceleration.H for source file icoUncoupledKinematicParcelDyMFoam.C
could not open file createPhi.H for source file icoUncoupledKinematicParcelDyMFoam.C
Unfortunately, this happens at all stages during the compile process.
I tried compiling it without the patch and that works flawlessly.
~roman
romant is offline   Reply With Quote
Old   October 21, 2011, 11:03
Default Need to match exact OpenFOAM 2.0.x for patch
  #16
gocarts's Avatar
Richard Smith
I think your compilation failed earlier. You need to find the first error to diagnose the problem.
The problem you are seeing is a symptom (not the cause) related to missing lnInclude directories.
My guess is that you patched the wrong version of OpenFOAM 2.0.x. Did you see errors during the patch process?
You have to exactly match the git version of OpenFOAM 2.0.x with the patch:
git commit: 2a7a68737dba87d82500df67029a15aeda662c42, Date: Sept. 14 11:28:07 2011
i.e.,
git clone http://github.com/OpenFOAM/OpenFOAM-2.0.x
cd OpenFOAM-2.0.x
git checkout 2a7a68737dba87d82500df67029a15aeda662c42
Old   October 21, 2011, 13:04
Default still occuring error
  #17
romant's Avatar
Roman Thiele
Hej Richard,
I did as you suggested
cd OpenFOAM-2.0.x
and then
installed the patch, which goes in without errors now
then i do
chmod ug+x <OpenFOAM-root>/src/gpu/Allwmake
WM_GPU='CUDA'
CUDA_ARCH_PATH=/home/roman/OpenFOAM/ofgpu-0-2
where I am not sure about the last one, ofgpu-0-2 contains
CMakeCache.txt  CMakeCache.txt~  CMakeFiles  cmake_install.cmake  CMakeLists.txt  COPYING.txt  install  install_manifest.txt  Makefile  ofgpu  README.txt
so i think i have it right, the library when I compiled it, never was under a install/release/lib folder but right away under install/lib so i didn't need to create the soft-link
I then start the compilation with
./Allwmake
and get the following first error
lex.yy.c:1391: warning: ‘yyunput’ defined but not used
lex.yy.c:1432: warning: ‘input’ defined but not used
+ set -e
+ wmakePrintBuild -check
version changed from previous build
+ /bin/rm -f OpenFOAM/Make/*/global.?
+ wmakeLnInclude OpenFOAM
wmakeLnInclude: linking include files to OpenFOAM/lnInclude
+ wmakeLnInclude OSspecific/POSIX
wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude
+ OSspecific/POSIX/Allwmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file signals/sigSegv.C
Making dependency list for source file signals/sigFpe.C
Making dependency list for source file signals/sigInt.C
Making dependency list for source file signals/sigQuit.C
Making dependency list for source file regExp.C
Making dependency list for source file fileStat.C
Making dependency list for source file timer.C
Making dependency list for source file POSIX.C
Making dependency list for source file clockTime/clockTime.C
Making dependency list for source file cpuTime/cpuTime.C
Making dependency list for source file memInfo/memInfo.C
Making dependency list for source file printStack.C
Making dependency list for source file fileMonitor.C
POSIX.C: In function ‘bool Foam::ping(const Foam::word&, Foam::label, Foam::label)’:
POSIX.C:1074:25: warning: use of old-style cast [-Wold-style-cast]
+ Pstream/Allwmake
+ wmake libso dummy
Making dependency list for source file UIPread.C
Making dependency list for source file UOPwrite.C
Making dependency list for source file UPstream.C
+ set +x
could not open file omp.h for source file UIPread.C
could not open file omp.h for source file UOPwrite.C
could not open file omp.h for source file UPstream.C
could not open file openmpi/ompi/mpi/cxx/mpicxx.h for source file UIPread.C
Making dependency list for source file PstreamGlobals.C
could not open file openmpi/ompi/mpi/cxx/mpicxx.h for source file UOPwrite.C
could not open file omp.h for source file PstreamGlobals.C
could not open file openmpi/ompi/mpi/cxx/mpicxx.h for source file UPstream.C
could not open file openmpi/ompi/mpi/cxx/mpicxx.h for source file PstreamGlobals.C
it then has exactly the same errors as before, that it can't open the header files for the C files, because it can't find them, like beginning with the gpu part
+ [ TRUE =  ]
+ gpu/Allwmake
+ wmake libso gpuless
Making dependency list for source file PBiCGgpu.C
Making dependency list for source file PCGgpu.C
+ wmake libso cuda
Making dependency list for source file cudaGpu.C
could not open file ofgpu/ofgpuconfig.h for source file cudaGpu.C
could not open file ofgpu/pbicg.h for source file PBiCGgpu.C
could not open file ofgpu/sparsematrixargs.h for source file PBiCGgpu.C
could not open file ofgpu/pcg.h for source file PCGgpu.C
could not open file ofgpu/sparsematrixargs.h for source file PCGgpu.C
PBiCGgpu.C:23:25: fatal error: ofgpu/pbicg.h: No such file or directorycudaGpu.C:23:31: fatal error: ofgpu/ofgpuconfig.h: No such file or directory
compilation terminated.
~roman
Old   October 21, 2011, 13:31
Default Paths wrong
  #18
gocarts's Avatar
Richard Smith
Errors I see:
  • "could not open file omp.h for source file UIPread.C"
  • "could not open file ofgpu/ofgpuconfig.h for source file cudaGpu.C"
So there's something wrong with your paths.
Don't bother compiling MPI (doesn't work with GPU), so set "WM_MPLIB=NONE"
Check that "/home/roman/OpenFOAM/ofgpu-0-2/ofgpu/*.h" exists
The fact that you don't have "<ofgpu-root>/install/release/lib" sounds like you didn't set "Set the CMAKE_INSTALL_PREFIX variable to <ofgpu-root>/install" or you didn't set the ofgpu build type to "release"
Check that the ofgpu build and install was successful.
Old   October 21, 2011, 15:31
Default bashrc args
  #19
gocarts's Avatar
Richard Smith
Another thought.
You have to supply your settings "WM_GPU='CUDA' CUDA_ARCH_PATH=/home/roman/OpenFOAM/ofgpu-0-2"
as args to etc/bashrc e.g.,:
export FOAM_INST_DIR="$(HOME)/projects/of/of2.0"; source $(FOAM_INST_DIR)/OpenFOAM-2.0.x/etc/bashrc WM_GPU='CUDA' CUDA_ARCH_PATH=/home/roman/OpenFOAM/ofgpu-0-2 etc...
arphy likes this.
Old   October 22, 2011, 09:34
Default Performance of OFGPU
  #20
Ahmad Lashgar
First I should thank gocarts for supporting OFGPU
I've succeeded to compile and run OpenFOAM-1.7.1 and OFGPU-0.1 and evaluate it. Here I have reported the performance comparison between CPU and GPU. The benchmark is pitzDailyGPU. One can run the benchmark using following commands:
blockMesh
simpleFoam
System CPU: AMD Opteron 6134
System GPU: NVIDIA Tesla C2050
For 12225 Cells:
CPU Time: 16 s
GPU Time: 45 s
For 122250 Cells:
CPU Time: 303 s
GPU Time: 105 s
For 299100 Cells:
CPU Time: 808 s
GPU Time: 186 s
Direct vs Iterative Linear Solvers for non-linears bill Main CFD Forum 16 November 5, 2014 07:18
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
New linear system solvers chegdan OpenFOAM Running, Solving & CFD 11 April 30, 2010 10:22
Water pump OpenFOAM 15 ANSYS CFX 110 comparation waynezw0618 OpenFOAM Running, Solving & CFD 39 March 5, 2009 12:57
Linear Solvers Sachin Main CFD Forum 0 May 6, 2006 12:07
