April 26, 2012, 18:17 |
Problem with SteamLine
Vincenzo Santoro
Rep Power: 14 |
Hi Foamers,
I'm Vincenzo and I have some problems with steamline in my solution. When I generate a map in Paraview I get image like these Instead, the result must be similar following Why the results obtained are difI would ask What's happen? |
April 26, 2012, 18:29 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Vincenzo and welcome to the forum!
Quick questions:
Best regards, Bruno
April 28, 2012, 10:08 |
Vincenzo Santoro
Rep Power: 14 |
Hi Bruno,
I'm sending the properties about steamline, where I use point source to generate steamline. I don't understand when you say: single or several steamline filter? Vincenzo |
April 28, 2012, 13:28 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Vincenzo,
You might also be interested in the following thread: http://www.cfd-online.com/Forums/ope...seed-type.html Best regards, Bruno
April 30, 2012, 18:00 |
Vincenzo Santoro
Rep Power: 14 |
Hi Bruno,
I tried to follow your advice but however it doesn't work. I suspect in my simulation there is something wrong. For example, when I run my solver (simpleFoam), after about 600 iterations, the scalar p is stopped, but simulation go on for 2700 iterations. Infact I see the message: no iteration 1000. Why happen? What's mean? I send you the main folders of my case http://vici.oceanprosystem.com/0.zip http://vici.oceanprosystem.com/constant.zip http://vici.oceanprosystem.com/system.zip Regards, Vincenzo Last edited by vinezio; April 30, 2012 at 19:17. |
May 1, 2012, 06:13 |
Bruno Santos
Rep Power: 128 |
Hi Vincenzo,
Unfortunately I don't have enough experience to help you on this. Perhaps it's best that you ask this last question on the other dedicated sub-forum: http://www.cfd-online.com/Forums/openfoam-solving/ Best regards, Bruno
May 1, 2012, 09:45 |
Martin
Rep Power: 21 |
Hi Vincenzo,
The "no iteration 1000" means: "number of iterations for pressure solver = 1000 iterations". The solution of the pressure equation system can't be improved any more. Your simulations convergence is fine and your initial residual for the pressure is already really low (for your mesh) after 700 iterations. You can add this line to the p solver settings in fvSolution: Code:
maxIter 50; // Default value is 1000; Martin |
May 24, 2012, 10:17 |
Vincenzo Santoro
Rep Power: 14 |
Thanks so much Martin, now i'm spending my time in better way, fortunately. thanks Bruno, you are the light in the darkness XD
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
