May 22, 2012, 06:57 |
ParaFoam crash, wireframe
Carles
Rep Power: 14 |
Hi all,
Iīm trying to visualize my mesh and i have some problems. I open ParaView 3.10.1 64-bit with my case. In the tab "properties" i have the mesh parts and the volume fields, I click to apply to load the internal mesh as well as the pressure and velocity field. It seems to work, I can visualize my geometry with style<representation<outline . But if I switch it to Wire-frame, the program is blocked, paralyzed. Do you have some idea about why I have this problem ? Another point, itīs that in the display menu i canīt choose to show pressure or velocity, although in the information tab, there are these fields, I means, it seems that the data were uploaded.... Thanks everyone, |
May 22, 2012, 16:02 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings CRT,
In my blog here at cfd-online you'll find this post: Related issues to ParaView with OpenFOAM - Fixes and solutions - hopefully you can find the solution in the links provided there. Either way, my diagnosis from your description is that something isn't connecting properly between ParaView and your graphics card, so there are two possibilities:
Bruno
May 24, 2012, 06:06 |
#3 | |
Carles
Rep Power: 14 |
Hi Bruno,
I was trying to use different drivers for the graphic card as well as another graphic card and it wasnīt work. A college found that the paraFoam program block a routine of Linux, thatīs something that shouldnīt happen. I mean, if thereīs a problem with the graphic card, etc. the program should be block, closed o whatever, but It shouldnīt block the whole system. Searching in internet he found people with the same problem, their purposed solution was to upgrade the version of SUSE, and recompile the programs, paraFoam and OpenFoam. Furthermore Iīm using my graphic card without the official drivers. Now I can visualize my mesh perfectly, but the second problem is still there Quote:
May 24, 2012, 16:10 |
Bruno Santos
Rep Power: 128 |
Hi Carles,
If you're not using the official drivers, then you're bound to sooner or later have serious problems You can also try running: Code:
foamToVTK Best regards, Bruno
Display Modes | |
[OpenFOAM] Unable to launch parafoam & | boonhow | ParaView | 5 | March 23, 2022 08:09 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY | raketenmaid | ParaView | 4 | February 5, 2013 05:20 |
paraFoam crash | FabOr | OpenFOAM | 5 | October 21, 2010 10:20 |
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit | sek | ParaView | 4 | August 17, 2006 16:26 |
