-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   paraview / paraFoam: bad, bad behaviour!!! (http://www.cfd-online.com/Forums/openfoam-paraview/102857-paraview-parafoam-bad-bad-behaviour.html)
aerospain June 4, 2012 14:50
Hi all,
I run ubuntu 12.04 in my machine. I was running 11.10 a couple of weeks ago and was NOT getting this behaviour from paraview/parafoam.
I have installed paraview3.12.0 from ThirdParty this afternoon in case that sorted my problems, but no luck! And, I get this behaviour either for openfoam2.1.0 or 2.1.1 results.
I'll leave the output to terminal I get from paraview (same from paraFoam) in case someone could help:
Thanks in advance!
C.
Got bus address: "unix:abstract=/tmp/dbus-FBe9dFYWYr,guid=a4eca58a83c7edeb0a4c37240000001b"
Connected to accessibility bus at: "unix:abstract=/tmp/dbus-FBe9dFYWYr,guid=a4eca58a83c7edeb0a4c37240000001b"
Registered DEC: true
Registered event listener change listener: true
FIXME: handle dialog start.
FIXME: handle dialog end.
QSpiAccessible::accessibleEvent not handled: "8008" obj: QObject(0x0) " invalid interface!"
QSpiAccessible::accessibleEvent not handled: "8008" obj: QComboBoxListView(0x11527e0) ""
Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!
akidess June 5, 2012 01:48
Try version 3.14?
niklas June 5, 2012 02:13
using my uber-google skills I pasted the error message in the search field and hit the search button
which lead me to this:
https://bugs.launchpad.net/ubuntu/+s...ot/+bug/997462
where it's claimed:
This "bug" seems to be resolved by removing the qt-at-spi package !
it took me 1 minute of hard innovative work and now i deserve to take a break.
aerospain June 5, 2012 14:58
uber-duber Niklas :-D
Thank you for the taking the time to google it. For once that I don't do it :-/
<Akidess> if you don't mind, i'll stick to 3.12 with Niklas' trick for the moment
cheers!
C.
