-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   paraview crashes (http://www.cfd-online.com/Forums/openfoam-paraview/102966-paraview-crashes.html)
Rezaslosh June 7, 2012 08:21
paraview crashes
Hello Foamers,
I'm trying to have a look at the results of damBreakPorousBaffle tutorial but paraveiw crashes when I load pressure and alpha fields. This doesn't happen for velocity U which is a volume vector field. For instance if I create U*alpha1 which is a vector field I can load it to Paraview with no problem. Below you can see the beginning part of the error message:
--> FOAM FATAL ERROR:
Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListIdEEEE
From function dynamicCast<To>(From&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/typeInfo.H at line 93.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/openfoam210/platforms/li
Has any one faced this problem before?
Any response is highly appreciated.
anon_a July 3, 2012 03:32
Hey there!
I am having the same problem, have you solved it?
anon_a July 3, 2012 04:09
It turns out it was not so difficult to solve.
http://www.cfd-online.com/Forums/ope...tml#post220998
Rezaslosh July 3, 2012 07:33
Thanks for the link. Wow, funny and amazing, it worked for me too. Reza
