Home > Forums > OpenFOAM Paraview & paraFoam
configuring paraFoam to use a different version of Paraview
Like Tree1Likes
  • 1 Post By olesen
Old   June 25, 2012, 10:21
Default configuring paraFoam to use a different version of Paraview
Mike Wallis
MikeWallis is on a distinguished road
Newbie question.
I'm compiling up 2.1.1 for a HPC system where we already have a version of ParaView installed. How do I configure parafoam to use this version, instead of having to compile the version that's in ThirdParty?
Thanks,
Mike.
MikeWallis is offline   Reply With Quote
Old   June 25, 2012, 16:12
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
I don't have a direct answer to your question… but… what I usually do is to create a .foam file within the case folder and then open it in paraview. It is almost the same as running paraFoam.
lovecraft22 is offline   Reply With Quote
Old   June 25, 2012, 17:36
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@Mike: it depends on the ParaView version you've got on your HPC system. Was it a custom build or did it come with the installed Linux distribution?
As lovecraft22 indicated, you can use the internal reader, by using the file extension ".foam". If you want this by default, edit the file paraFoam and change the line:
# reader extension
extension=OpenFOAM
To:
# reader extension
extension=foam
To know where paraFoam is located:
which paraFoam
In case you have a custom build of ParaView and still have the development files around (preferably installed as well), then edit the file "etc/config/paraview.sh" in OpenFOAM's folder.
Best regards,
Bruno
Old   June 26, 2012, 02:28
Mark Olesen
olesen will become famous soon enough
Everything else is good, but I'd make a slight improvement here:
The preferred solution is given indicated in the etc/config/example/paraview.sh file. You'd make a copy of this in your site-wide or user-specific OPENFOAM directory (see "foamEtcFile -list")
Your modified version hooks into the shipped version:
foamFile=$($WM_PROJECT_DIR/bin/foamEtcFile -mode o config/paraview.sh 2>/dev/null) && . $foamFile ParaView_VERSION=3.9.0
unset foamFile
This makes it easier to carry across your modifications to a newer OPENFOAM version (if needed) and avoids needing to touch the shipped files at all.
wyldckat likes this.
olesen is offline   Reply With Quote
Old   June 26, 2012, 11:45
Mike Wallis
Thanks, everybody! The point of all this is so that I can build and deploy OpenFOAM as a module for multiple users on the cluster, and there are users of ParaView on the system who don't use OpenFOAM so I'd like to keep the two applications as separated as possible.
You've been really helpful and I really appreciate it.
Thread Tools
Trackbacks are On
How to view openfoam results in paraview Marineboy OpenFOAM Paraview & paraFoam 5 July 10, 2012 03:14
paraview / paraFoam: bad, bad behaviour!!! aerospain OpenFOAM Paraview & paraFoam 3 June 5, 2012 14:58
wmake error zxj160 OpenFOAM 0 March 26, 2012 10:52
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 8 December 18, 2009 12:14
ParaView patch visualisation error in Development version philippose OpenFOAM Paraview & paraFoam 17 March 26, 2007 06:45
