-   OpenFOAM Paraview & paraFoam (
-   -   Bug in Paraview reader? Color wrongly interpolated? (
1/153 August 3, 2012 10:37
Hi guys,
What if you open the channel flow case and set an initial velocity in the internal field as a constant U_internal=UC, and using parafoam to see the velocity contour, I found the inlet and outlet cells are not colored as UC, but it seems to be (0+UC)/2.
I am using paraview 3.14.1, 64 bits, Ubuntu, of 2.1
Anyone can confirm my finding?
wyldckat August 3, 2012 13:34
Hi 1/153 * dw :)
What's the representation form you're using? Namely, when you choose the field to be represented, is it the cell center mode or the point/vertex mode?
If it's the point mode, it's natural that you're picking up the "no-slip wall" boundary condition, where U is 0.
Best regards,
1/153 August 3, 2012 16:12
1 Attachment(s)
Attachment 14976
See the inlet cells.
I am using point mode as I did before. No problem before, it must be something different in this version I guess.
And using paraFoam -builtin, I have no problem.
wyldckat August 4, 2012 05:37
Does the same happen with a tutorial case such as "incompressible/simpleFoam/pitzDaily"?
