Home > Forums > OpenFOAM Paraview & paraFoam
Update data in ParaView 3.14
Like Tree1Likes
  • 1 Post By wyldckat
Old   August 6, 2012, 07:33
Default Update data in ParaView 3.14
Robert Sawko
AlmostSurelyRob will become famous soon enough
sorry for bumping a two years old thread, but I am on ParaView 3.14 and non-Ubuntu Linux and I cannot seem to find any reload button nor "Update GUI" checkbox? How can I reload data for my cases?
AlmostSurelyRob is offline   Reply With Quote
Old   August 7, 2012, 06:59
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Hi Robert,
You didn't need to bump an old thread, you could have started a new thread altogether ...
Anyway, what reader are you using in ParaView? The one that comes internally in ParaView or the one that OpenFOAM has?
The easiest way to tell them apart is: which file extension are you opening with? "case.foam" or "case.OpenFOAM"?
Best regards,
Bruno
wyldckat is online now   Reply With Quote
Old   August 7, 2012, 17:22
Robert Sawko
It's always a grey area for me: should I start a new thread or should I just continue when there seems to be such a relevant post already there. Next time I'll just do a link!
I am using foam extension. I always create it with touch command and then open it from paraview which I compile or download separately.
Old   August 7, 2012, 18:23
Bruno Santos
Hi Robert,
I've moved our posts to a new thread
OK, so you're using the internal reader. Currently the internal reader provided in ParaView doesn't have quick update button.
To replicate this functionality, what I usually do is the following steps:
  1. Tick the check box "List timesteps according to controlDict". It's on the lower part of the "Object Inspector", tab "Properties".
  2. Hit the "Apply" button.
  3. Untick the check box "List timesteps according to controlDict".
  4. Hit the "Apply" button once again.
The other solution is to change the "Case Type" between decomposed and reconstructed mode or vice-versa.
Best regards,
Bruno
David* likes this.
Thread Tools
Trackbacks are On
Paraview on windows 7, forced scaling of data mikemech OpenFOAM Paraview & paraFoam 8 September 26, 2011 13:11
export data from paraview lions85 OpenFOAM 4 June 2, 2011 13:33
paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
ParaView shows a list of data types and ask for it idrama OpenFOAM 1 August 20, 2010 07:08
From FLUENT data to Paraview bart weisser FLUENT 1 July 16, 2010 04:41
