[Sponsors] | |||||
Rep Power: 3 ![]() |
hi @ all,
simple question. I would like to create a Slice through a domain. The only problem I have is that the Slice is cutting the Elements into small peaces. I would like to show the whole Elements which where cut by the Slice. Any Idea? Thanks a lot Dito |
Philip,
thanks a lot, I will try. Cheers, Dito |
zaynah K.
Rep Power: 2 ![]() |
hi..
i did the above steps and it didnot show my plane.. ![]() i wish to see a plane from my 3d domain. i use the slice. and i display etc.. nothing works..![]() ihelp needed Last edited by zaynah04; March 18, 2013 at 11:51. |
#5 | |
Philip Cardiff
Rep Power: 9 ![]() |
if you describe the steps you have taken in detail then it may be possible to find the problem. The above procedure works fine for me, additionally in the latest ParaView (version 3.98) you can use the "slice" filter and turn on the "Crinkle slice" option. Philip |
zaynah K.
hi
It did work after a lot of trials.. i am sorry i forget to post that it worked.. i have one question how do i display vector field in paraview? i usually display velocity plot usiing glyph filter.. thanks a bunch zaynah |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [ICEM] Negative Volumes & 7 node HEXA elements | mr_stoked | ANSYS Meshing & Geometry | 1 | September 21, 2010 12:45 |
| elements, nodes and faces | Andy | CFX | 7 | December 4, 2006 16:03 |
| Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 08:06 |
| CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
