Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] vorticity resolution in paraFoam
Like Tree3Likes
  • 1 Post By Tobi
  • 2 Post By Tobi
Old   September 4, 2012, 18:35
Default vorticity resolution in paraFoam
Elh. A2. BAH
ebah6 is on a distinguished road
Dear all,
I am using the "Filters/calcualteDerivatives" option to visualise the vorticity magnitude. But the resolution is quite not good.
Attached are two snapshots of the velocity magnitude and the vorticity magnitude.
Can someone direct me on how to get a resolution of the vorticity similar to that of the velocity?
Please, note that in the down-scroll bar, the velocity can be show with a bad resolution as well. But the vorticity has the bad one only.
best regards.
ebah6 is offline   Reply With Quote
Old   September 6, 2012, 10:05
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by ebah6 View Post
Dear all,
best regards.
Hi ebah,
do you mean sth like that (attachment)?
I used icoFoam and the post-utility "vorticity"; there you get the interpolation solution.
Hope it helps you.
Tobi
amir.a.aliabadi likes this.
Tobi is offline   Reply With Quote
Old   September 6, 2012, 13:32
Elh. A2. BAH
Thank you Tobias,
This is what I need.
Can tell how you obtain it.
Say I have run my case and have the velocity field; how can continue from there?
Or should I re-start the run and compute the vorticity in the same manner as the pressure and velocity fields?
Thank you for time.
Old   September 6, 2012, 16:31
Tobi's Avatar
Tobias Holzmann
Thank you Tobias,
Thank you for time.
you just have to type
vorticity
after your simulation in your case directory.
After that the utility calculates the vorticity from the velocity field.
Tobi
SUBHANKAR and EddySouth like this.
Old   September 6, 2012, 17:05
Elh. A2. BAH
Thank you very much.
This works perfect.
my best regards.
Old   February 26, 2014, 10:01
Default Doesn't show vorticty?
Olie
odellar is on a distinguished road
I've used the vorticity, and ptot utilities after solving for my case, and it computes the vorticity and ptot fields (I can tell it's worked because the data is there in the folders 0, 0.1, etc) but when I open the case in ParaFoam it still only gives me options to display U, Umag, and p, not vorticity or ptot -- how do I get this?
Thanks
Olie
odellar is offline   Reply With Quote
Old   February 26, 2014, 10:04
Default Fixed!
Olie
Originally Posted by odellar View Post
Thanks
Olie
Sorry forget this - just found it!
Old   November 19, 2014, 09:27
Soham Harshe
Soham Harshe is on a distinguished road
I am having the same problem. Can you please tell how to fix this ?
Soham Harshe is offline   Reply With Quote
Old   June 15, 2015, 12:30
Rui Wang
wanrui is on a distinguished road
Sorry, how did you find the ptot data? I have the same problem in finding it in the paraFoam
wanrui is offline   Reply With Quote
Old   November 21, 2015, 12:17
TehHO is on a distinguished road
When I use this utility and type vorticity after my simulation I do get the poor resolution aswell. How do you interpolate the values? Can you elaborate?
And sorry for posting in such old thread :-)
TehHO is offline   Reply With Quote
Old   March 28, 2016, 09:30
Jack
Jack001 is on a distinguished road
If you use the paraview filter Cell to Point Data then the resolution looks better for any field or scalar variable because I'm guessing that paraview interpolates data at each point from the cell centered value. Could this be an option?
Jack001 is offline   Reply With Quote
Old   December 11, 2017, 16:03
farzane
irfkh is on a distinguished road
Dear Foamer
I work on plunging airfoil and I want to have some line like attach picture in downstream. please help me what should I do? is it vorticity line on velocity contour?
irfkh is offline   Reply With Quote
Vorticity with pimpleDyMFoam Idasg OpenFOAM Post-Processing 1 March 6, 2019 04:16
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
Choice of numerical schemes for high accuracy in vorticity D.B OpenFOAM Running, Solving & CFD 1 February 5, 2018 10:44
High resolution image with parafoam Andrea_85 OpenFOAM 5 January 23, 2014 06:39
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
