Home > Forums > OpenFOAM Paraview & paraFoam
Paraview: how to plot streamlines and surface mesh together
Like Tree1Likes
  • 1 Post By wyldckat
Old   September 7, 2012, 05:37
Default Paraview: how to plot streamlines and surface mesh together
Serena
serena is on a distinguished road
It's probably just a stupid question, but well...
I need to plot the streamlines around a wheel.
In the mesh parts I have
1) an outer mesh (If I plot the wireframe of the outer mesh I can see in the middle the streamlines but it's a bit chaotic)
2) the wheel_* patches that are the surface meshes of the model inside the outer mesh.
I would like to plot those wheel_* patch mesh surfaces and the streamlines, together.
How to?
serena is offline   Reply With Quote
Old   September 7, 2012, 21:14
Serena
I try to explain me better:
I have an external mesh and when I plot it I can see the streamlines together. But I can't see them well because the wireframe of the external mesh covers them. What I just want to see are the surfaces of the model with around the streamlines. So I plot the surfaces of the model and hide the external mesh. I would like to hide just the external mesh but also the streamlines desappear.
If you have time to give it a try check the files at
https://www.dropbox.com/sh/gg1ypj0c1sftemx/Ct7derbpHh
Old   September 8, 2012, 15:04
Bruno Santos
wyldckat has a spectacular aura aboutwyldckat has a spectacular aura about
Greetings Serena,
If I understand you correctly, what you seem to be doing wrong is to try and use only one file object for both representations.
The trick is to load the same file twice:
  • One for the surfaces.
  • Another for the volume data, where you hide the mesh and should only the streamlines
Best regards,
Bruno
serena likes this.
Old   September 9, 2012, 22:13
Serena
Thank you so much Bruno!
Very nice trick, works!
Serena
Thread Tools
Trackbacks are On
[CFD Post] Surface streamlines not located where needed siw CFX 1 July 7, 2011 19:13
3D graph of lift/drag forces (coeffs) on a surface - is it possible in paraview??? Domi OpenFOAM Paraview & paraFoam 1 May 19, 2011 07:16
meaning of surface streamlines Nick R CFX 3 November 5, 2010 16:17
Surface streamlines on axial flow fans Jennifer CFX 2 February 17, 2009 14:50
Paraview Questions Freeman ParaView 7 February 20, 2006 15:51
