-   ParaView (https://www.cfd-online.com/Forums/paraview/)
-   -   [OpenFOAM] 2 cases with 2 identical slices and calculator (https://www.cfd-online.com/Forums/paraview/106860-2-cases-2-identical-slices-calculator.html)
Tobi September 11, 2012 04:20
Hi all,
I have a question to you.
Is it possible to build 2 cases with (for example) different velocity and then load the 2 cases into paraview.
For each case you generate a slice and now you wanna calculate the differences between the two slice values (like pressure).
I did something like that:
- load case1
- create slice1
- calculator on case1
- pressure1 = p
- load case2
- create slice2
- calculator on case2
- pressure2 = p
- group datasets (on the both calculators)
- calculator
- pressureDiff = pressure1 - pressure2
ERROR
ERROR: In ..\..\..\..\src\VTK\Common\vtkFunctionParser.cxx, line 1480
vtkFunctionParser (000000006A725A20): Syntax error: expecting a variable name;  see position 4
Warning: In ..\..\..\..\src\VTK\Graphics\vtkArrayCalculator.cxx, line 401
vtkPVArrayCalculator (000000003FD1EAA0): An error occured when parsing the calculator's function.  See previous errors.
vtkFunctionParser (00000000696B8C00): Syntax error: expecting a variable name;  see position 10
Any suggestions or is it possible to do sth. like that?
Thanks in advance
Tobi
