Home > Forums > Visualization & Post-Processing Software > ParaView
[General] How to use paraview to mark something on the object
Old   June 4, 2012, 08:13
Default How to use paraview to mark something on the object
Sun
notian is on a distinguished road
Hi all,
I am new for paraview, and thank in advance for all kinds of help.
My question : I am doing the visualization of a wheel rotating on the road, and want to do some marks (e.g line, circle...) on the wheel so that we can see the wheel is rotating but not just moving on the road. But I do not know how to do it. Please help me.
notian is offline   Reply With Quote
Old   June 4, 2012, 14:42
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi
You can add many objects (e.g. line, sphere, etc) to your visualization by using the sources drop-down menu.
Edit: Sorry it seems I missunderstood your question. I think after adding the source you need to open the animation view and edit the object for time or consider writing a python script.
Regards
Hisham is offline   Reply With Quote
Old   June 4, 2012, 17:15
Sun
Originally Posted by Hisham View Post
Hi
Regards
Sorry, maybe I did not describe the question clearly. I mean I want to mark something on the wheel which can also move with the wheel, i.e they move together, so that we can see the wheel is rotate on the road but not slither. Thanks.
Old   June 4, 2012, 17:44
Hisham's Avatar
Hisham Elsafti
Hi
I don't know how to do this the "right" way, but I have a suggestion.
1. make a calculator filter that calculates a field based on the coodinates (e.g. coordsX)
2. select to view the result from this filter (just like any other field)
3. manipulate the color map to yield two colors one of them will be for a slice of the wheel and the other will be for the rest (rescale range from the desired x "end of slice" and another preceeding number that is very close)
4. run animation
Nevertheless, I am sure there is a more "humane" method
Regards
Old   June 5, 2012, 17:48
Sun
Thanks, man. But it is not what I want.
Old   September 26, 2012, 17:43
nooj
nooj is on a distinguished road
Create a separate mesh file with spokes or rims in it.
Chances are you generally use the same sized wheel repeatedly, so you can re-use the same rims for multiple simulations.
Or create a separate mesh with a single vertex at one spot on the wheel, and render this vertex with a glyph of your choosing (sphere).
nooj is offline   Reply With Quote
engineFoam with layers - pressure problems when adding layers mturcios777 OpenFOAM Running, Solving & CFD 23 January 4, 2023 21:56
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[OpenFOAM.org] ParaView Installation: Python problem KateEisenhower OpenFOAM Installation 5 August 24, 2017 05:27
Paraview version update errors Dan Pearce OpenFOAM Installation 5 January 8, 2014 05:47
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
