Home > Forums > OpenFOAM Paraview & paraFoam
paraview server and mpi
Old   November 2, 2012, 14:55
Default paraview server and mpi
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Dear all.
I've installed OF and paraview fia apt-get on a new ubuntu machine that will be used as muscle for my pre and post processing.
i can start the paraview server there and connect to it from my machine with the client. no issues about that
BUT i cannot start more than 1 pvserver. i'd like to make full use of the cores on that machine.
what i tried is:
mpirun -np 4 pvserver --use-offscreen-rendering
and the output is
Waiting for client
Connection URL: cs://localhost:11111
Waiting for client
Waiting for client
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/Common/vtkSocket.cxx, line 258
vtkServerSocket (0x26a6f90): Socket error in call to listen. Address already in use.
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/ParaViewCore/ClientServerCore/vtkTCPNetworkAccessManager.cxx, line 286
vtkTCPNetworkAccessManager (0x1f28a30): Failed to set up server socket.
Exiting...
vtkServerSocket (0x1e44f90): Socket error in call to listen. Address already in use.
Exiting...
vtkTCPNetworkAccessManager (0x16c6a30): Failed to set up server socket.
Waiting for client
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/Common/vtkSocket.cxx, line 206
vtkServerSocket (0x1085f90): Socket error in call to bind. Address already in use.
Exiting...
vtkTCPNetworkAccessManager (0x907a30): Failed to set up server socket.
Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!
^Cmpirun: killing job...
I've found on a paraview mailing list a similar error :
http://www.paraview.org/pipermail/pa...ry/024001.html
and the solution provided was to
Verify that the paraview is built with mpi enabled (PARAVIEW_USE_MPI cmake flag must be ON). In most likelihood, it's not.
I think that this solution requires to recompile paraview from source. i was hoping to avoid it. any ideas on how fix this issue?
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Thread Tools
Trackbacks are On
Star-CD with ParaView usker STAR-CD 3 December 9, 2015 15:20
Paraview in Prallel (server-client) prapanj OpenFOAM Paraview & paraFoam 11 September 24, 2010 07:12
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 07:27
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
