Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Viewing 3D fluid flow in ParaView
Old   November 5, 2012, 13:58
Default Viewing 3D fluid flow in ParaView
smschnob is on a distinguished road
Greetings,
I would like to view 3-dimensionally, in ParaView, the spray from a slit nozzle. However, if I attempt to visualize this in ParaView the spray is obstructed from view by the surrounding volume. For example, if I look at phase fraction, the spray is obstructed from view by all of the regions with zero phase fraction. Do I need to modify the solver to hide regions with zero phase fraction? If so, how would I do this? I'm not sure if I'm explaing this very well. I have included a screenshot, which hopefully offers some more clarity. In addition, I used the interFoam solver. Any help anyone can provide would be very much appreciated? Thank you!
smschnob is offline   Reply With Quote
Old   November 5, 2012, 17:06
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
You might want to plot only the contour of alpha1 = 0.5, then you can see the spray I think. Another option is to reduce the Opacity of the entire domain, in that sense you can easily see the slice you made. But I think the first method is better.
Duong
duongquaphim is offline   Reply With Quote
Old   November 6, 2012, 16:56
Thank you for the help! I was able to see the spray by creating contour plots as well as threshold plots.
3d spray, interfoam, nozzle flow, paraview
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Multiphase flow with two continuous fluids and one dispersed fluid ashtonJ CFX 5 July 25, 2014 06:31
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
