Home > Forums > Visualization & Post-Processing Software > ParaView
[General] .dat files Windows vs Linux
Old   January 3, 2013, 14:20
Default .dat files Windows vs Linux
mjforsteruk is on a distinguished road
When I want to open a Tecplot .dat file in Windows and my schools CentOs, I have 3 options of filetype and neither works. However in Ubuntu I have many options and the Tecplot option works perfectly.
Is there an add-on in the Ubuntu version that is not in Windows, and can I add it to the Windows version so they both work as required?
Thanks
If I try the ParaDIS Tecplot option I get:
ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Common\ExecutionMode l\vtkExecutive.cxx, line 753 vtkPVCompositeDataPipeline (000000000D67E650): Algorithm vtkVisItParaDISTecplotReader(000000000D98A280) returned failure for request: vtkInformation (000000000D60BB30)
Debug: Off
Modified Time: 107582
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA_OBJECT
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
mjforsteruk is offline   Reply With Quote
Old   January 7, 2013, 15:14
Retired Super Moderator
Bruno Santos
Greetings mjforsteruk,
There are two possible explanations for the differences you're getting:
  1. You might be using two very different versions of ParaView on each machine.
  2. The ".dat" file, is it a text file or a binary file? If it's a text file on Linux, then ParaView on Windows might be mistakenly assume it's a binary file. If this is the case, you might want to try an application named "unix2dos".
More possible solutions:
  • From the error message, it looks like you're using ParaView 3.98.0 on Windows. Try using ParaView 3.14.1 instead.
  • Since it's a Tecplot file, rename the file extension from ".dat" to ".tec".
Best regards,
Bruno
Old   January 7, 2013, 15:37
Hi Bruno,
Thanks for your reply. I have changed the filetype to .tec which works on 3.98.0 64 bit on windows (I havent tried the centos version).
I was running 3.14.1 64bit on windows but upgraded in the hope that my problem was a bug that was rectified. I cant remember what version my university machines are using but Ubuntu is running 3.14.1 64bit.
The .dat file is a text file, but I can open it in notepad and also the Linux machine the file was created on wouldnt open it in paraview. Ive not had a problem with other dat files from linux fluent to windows.
Anyway, it now works great as a .tec so thanks very much!
[GAMBIT] Gambit works on Windows, but not in Linux victorz ANSYS Meshing & Geometry 8 April 14, 2013 20:40
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
Ansys windows vs linux benchmark mr_aliagha ANSYS 0 November 28, 2011 15:50
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 03:26
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
