Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraFoam with paraview 3.8.1
Old   January 10, 2013, 22:38
Default paraFoam with paraview 3.8.1
nsreddy
nsreddysrsit is on a distinguished road
hi,
I am unable to open paraFoam
I am getting the following error :
/opt/paraviewopenfoam381/lib/paraview-3.8/paraview: symbol lookup error: /usr/lib/libQtNetwork.so.4: undefined symbol: _ZN16QIODevicePrivate4peekEPcx
any Help
Regards
nsreddysrsit is offline   Reply With Quote
Old   January 13, 2013, 08:48
Retired Super Moderator
Bruno Santos
Greetings nsreddy,
We'll need some more information in order to help you:
  • Which OpenFOAM version do you have installed?
  • How did you install OpenFOAM?
    The error message you've got suggests that you installed from Deb or RPM packages, but it also suggests that you installed said packages in an unsupported system.
  • Which Linux Distribution are you using? Fedora, Ubuntu or openSUSE?
  • Which version of that Linux Distribution?
  • Which architecture of that Linux Distribution? 32bit or 64bit?
  • Do you have more than one OpenFOAM installation installed? If so, how are you keeping them apart?
Best regards,
Bruno
Old   January 15, 2013, 00:38
nsreddy
thanks for the reply,
I am using Ubuntu 10.10, paraFoam 3.82,Openfoam 1.71
I installed through Deb pack ,
When I install 3G Modem (Vision Tech) ,the error i am getting,
When I uninstall, ParaFoam working correctly.
Best regards,
N S reddy
Old   January 19, 2013, 16:29
Bruno Santos
Best regards,
N S reddy
Hi N S reddy,
That's a somewhat strange error you're getting... looks like the modem you're installing is either modifying or affecting Ubuntu's version of Qt, which leads ParaView to not work properly.
There are at least two possible solutions:
  1. You can try and find how the modem software is affecting the Qt library. Run:
    cd /opt/paraviewopenfoam381/lib/paraview-3.8
    ldd ./paraview
    If you can show us the output from this last command, we might be able to diagnose where the problem is and what might be a good solution.
  2. Or you can try and follow these instructions for replacing the ParaView version you've got installed: http://www.cfd-online.com/Forums/blo...-openfoam.html - these instructions will help you install the pre-built version of ParaView available at paraview.org, which already comes with its own Qt libraries.
Best regards,
Bruno
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 18:03
How to get Python Shell into ParaView 3.8.1? blaise OpenFOAM Installation 3 July 24, 2012 05:58
OF 1.7.0 & paraView 3.8.1 (paraFoam) maysmech OpenFOAM 8 November 3, 2010 02:10
[OpenFOAM] parafoam - paraview help function felik9 ParaView 5 June 3, 2010 16:03
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit nanes ParaView 2 September 11, 2009 10:12
