-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Error when loading Paraview-3.12.0 (http://www.cfd-online.com/Forums/openfoam-paraview/114230-error-when-loading-paraview-3-12-0-a.html)
aevub March 7, 2013 08:39
Hi
I just compiled OpenFOAM 2.1.x and Paraview -3.12.0, but when I run both paraFoam as paraview i get this error:
ERROR: In /usr/local/OpenFOAM/ThirdParty-2.1.x/Paraview-3.12.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404 vtkXOpenGLRenderWindow (0x93d3e08): Could not find a decent visual
It opens paraview, but none of the buttons (f.e. to open & load data) work. The whole thing freezes and the only way to close it is to kill it in the terminal.
Any idea what could be the problem and how to solve it?
Thank you!
wyldckat March 7, 2013 09:33
Greetings aevub,
Check the links in this blog post of mine: Related issues to ParaView with OpenFOAM - Fixes and solutions -more specifically, the links in the section "Problems with Visualization".
Best regards,
Bruno
aevub March 7, 2013 10:42
Hi Bruno
I tried to do
export LIBGL_ALWAYS_INDIRECT=y
in the terminal & in the bashrc
But I still have the same error + 3 new lines:
QVariantMap DBusMenuExporterDBus::getProperties(int, const QStringList&) const: Condition failed: action
:confused:
wyldckat March 7, 2013 17:46
Hi aevub,
That's only one of several possible solutions. The issue can be one of several:
  • problems with incorrectly installed graphics drivers;
  • the desktop using 3D by default, which collided with ParaView's accesses to OpenGL and the graphics card;
  • compiling ParaView with an incompatible Qt version...
And I think I'm forgetting some more... which is one of the reasons why I merely posted the previous link. The other reason is because I don't have much time in these few days, so it was the quickest answer ;).
You can also try and take a look at the following thread for more ideas: http://www.cfd-online.com/Forums/ope...-paraview.html
Best regards,
Bruno
aevub March 11, 2013 05:36
Hi
I started to look in detail to the log file when compiling, and there is an error in Allmake.stage3.
Package libccmio-2.6.1 can't be reached (failed to connect to site).
Any ideas?
Edit: This is for OF16ext.
For 2.1x I still get errors when oipening parafoam, but it works for the moment.
wyldckat March 11, 2013 08:44
Quick answer: libccmio is not crucial for OpenFOAM to function.
It is in fact necessary to ask permission to cd-Adapco for the usage of this library: http://www.openfoam.org/mantisbt/view.php?id=61
aevub March 25, 2013 03:33
Hi
I had to reinstall everything on a different server (ubuntu 12.04), but I keep getting the same errors:
created temporary 'cavity21x.OpenFOAM'
Xlib: extension "XInputExtension" missing on display ":10.0".
ERROR: In /usr/local/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404
vtkXOpenGLRenderWindow (0x2443340): Could not find a decent visual
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Major opcode: 62 (X_CopyArea)
Resource id: 0x0
*** glibc detected *** /usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview: munmap_chunk(): invalid pointer: 0x000000000322e9f0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7f2f9cd0cb96]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkRendering.so.pv3.12(_ZN21vtkOpenGLRenderWind ow12GetPixelDataEiiiiiPh+0xd4)[0x7f2f9a994294]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libQVTK.so.pv3.12(_ZN10QVTKWidget16saveImageToCach eEv+0xe3)[0x7f2f9ad82c33]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkCommon.so.pv3.12(_ZN18vtkCallbackCommand7Exe cuteEP9vtkObjectmPv+0x19)[0x7f2f9b656e59]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkCommon.so.pv3.12(+0x186de6)[0x7f2f9b6fade6]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkRendering.so.pv3.12(_ZN15vtkRenderWindow15Co pyResultFrameEv+0x5c)[0x7f2f9a8fb06c]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkRendering.so.pv3.12(_ZN15vtkRenderWindow6Ren derEv+0x1bd)[0x7f2f9a8fc1dd]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkRendering.so.pv3.12(_ZN22vtkXOpenGLRenderWin dow6RenderEv+0x3e)[0x7f2f9a9d3eee]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVClientServerCore.so(_ZN15vtkPVRenderView6R enderEbb+0x36a)[0x7f2f9bda18ea]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVClientServerCore.so(_ZN15vtkPVRenderView11 StillRenderEv+0x3c)[0x7f2f9bd9fdec]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVClientServerCoreCS.so(_Z22vtkPVRenderViewC ommandP26vtkClientServerInterpreterP13vtkObjectBas ePKcRK21vtkClientServerStreamRS5_+0x1602)[0x7f2f96597c42]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkClientServer.so(_ZN26vtkClientServerInterpre ter20ProcessCommandInvokeERK21vtkClientServerStrea mi+0x19e)[0x7f2f9914957e]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkClientServer.so(_ZN26vtkClientServerInterpre ter17ProcessOneMessageERK21vtkClientServerStreami+ 0x4f5)[0x7f2f99147de5]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkClientServer.so(_ZN26vtkClientServerInterpre ter13ProcessStreamERK21vtkClientServerStream+0x1d)[0x7f2f9914813d]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVServerImplementation.so(_ZN16vtkPVSessionC ore21ExecuteStreamInternalERK21vtkClientServerStre amb+0x10c)[0x7f2f9c046fcc]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVServerImplementation.so(_ZN16vtkPVSessionC ore13ExecuteStreamEjRK21vtkClientServerStreamb+0x4 c)[0x7f2f9c04688c]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVServerImplementation.so(_ZN16vtkPVSessionB ase13ExecuteStreamEjRK21vtkClientServerStreamb+0x4 2)[0x7f2f9c045be2]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVServerManager.so(_ZN10vtkSMProxy13ExecuteS treamERK21vtkClientServerStreambj+0x5e)[0x7f2f9c4d30ce]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkPVServerManager.so(_ZN14vtkSMViewProxy11Stil lRenderEv+0x89)[0x7f2f9c524399]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libQVTK.so.pv3.12(_ZN10QVTKWidget10paintEventEP11Q PaintEvent+0xb1)[0x7f2f9ad82f51]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN7QWidget5eventEP6QEvent+0x636)[0x7f2f9dc520f6]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN19QApplicationPrivate13notify_hel perEP7QObjectP6QEvent+0xb4)[0x7f2f9dc01894]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6 QEvent+0x113)[0x7f2f9dc06713]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication14notifyIntern alEP7QObjectP6QEvent+0x8c)[0x7f2f9d6dee9c]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN14QWidgetPrivate10drawWidgetEP12Q PaintDeviceRK7QRegionRK6QPointiP8QPainterP19QWidge tBackingStore+0x3e6)[0x7f2f9dc4dd96]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN14QWidgetPrivate11repaint_sysERK7 QRegion+0x157)[0x7f2f9de19787]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN14QWidgetPrivate16syncBackingStor eEv+0x24)[0x7f2f9dc44a64]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN7QWidget5eventEP6QEvent+0xb4c)[0x7f2f9dc5260c]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendP ostedEventsEP7QObjectiP11QThreadData+0x46a)[0x7f2f9d6e2c6a]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1a9f93)[0x7f2f9d70df93]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x133)[0x7f2f98a3bd53]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x480a0)[0x7f2f98a3c0a0]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x34)[0x7f2f98a3c164]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN20QEventDispatcherGlib13processE ventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0 x6f)[0x7f2f9d70e3bf]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x273d5e)[0x7f2f9dca9d5e]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFl agsINS_17ProcessEventsFlagEE+0x32)[0x7f2f9d6ddc82]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17P rocessEventsFlagEE+0xf7)[0x7f2f9d6dded7]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x87)[0x7f2f9d6e2f67]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview(main+0x147)[0x405ff7]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7f2f9ccaf76d]
/usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview[0x4061c1]
======= Memory map: ========
00400000-004b1000 r-xp 00000000 fc:05 142848 /usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview
006b0000-006b1000 r--p 000b0000 fc:05 142848 /usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview
006b1000-006b2000 rw-p 000b1000 fc:05 142848 /usr/local/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/paraview
017b0000-037ad000 rw-p 00000000 00:00 0 [heap]
7f2f7963b000-7f2f7963c000 ---p 00000000 00:00 0
7f2f7963c000-7f2f79e3c000 rw-p 00000000 00:00 0
7f2f79e3c000-7f2f79e3d000 ---p 00000000 00:00 0
7f2f79e3d000-7f2f7a63d000 rw-p 00000000 00:00 0
7f2f7a63d000-7f2f7a63e000 ---p 00000000 00:00 0
7f2f7a63e000-7f2f7ae3e000 rw-p 00000000 00:00 0
7f2f7ae3e000-7f2f7ae3f000 ---p 00000000 00:00 0
7f2f7ae3f000-7f2f7b63f000 rw-p 00000000 00:00 0
7f2f7b971000-7f2f7cc4c000 r-xp 00000000 fc:00 35189 /usr/lib/x86_64-linux-gnu/libLLVM-3.0.so.1
7f2f7cc4c000-7f2f7ce4c000 ---p 012db000 fc:00 35189 /usr/lib/x86_64-linux-gnu/libLLVM-3.0.so.1
7f2f7ce4c000-7f2f7cfc5000 r--p 012db000 fc:00 35189 /usr/lib/x86_64-linux-gnu/libLLVM-3.0.so.1
7f2f7cfc5000-7f2f7d0d9000 rw-p 01454000 fc:00 35189 /usr/lib/x86_64-linux-gnu/libLLVM-3.0.so.1
7f2f7d0d9000-7f2f7d0ed000 rw-p 00000000 00:00 0
7f2f7dd75000-7f2f7e164000 rw-p 00000000 00:00 0
7f2f7e164000-7f2f7e16d000 r-xp 00000000 fc:00 175085 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f2f7e16d000-7f2f7e36c000 ---p 00009000 fc:00 175085 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f2f7e36c000-7f2f7e36d000 r--p 00008000 fc:00 175085 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f2f7e36d000-7f2f7e36e000 rw-p 00009000 fc:00 175085 /usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so
7f2f7e36e000-7f2f7e37a000 r-xp 00000000 fc:00 128592 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f2f7e37a000-7f2f7e579000 ---p 0000c000 fc:00 128592 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f2f7e579000-7f2f7e57a000 r--p 0000b000 fc:00 128592 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f2f7e57a000-7f2f7e57b000 rw-p 0000c000 fc:00 128592 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f2f7e57b000-7f2f7e585000 r-xp 00000000 fc:00 128588 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f2f7e585000-7f2f7e785000 ---p 0000a000 fc:00 128588 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f2f7e785000-7f2f7e786000 r--p 0000a000 fc:00 128588 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f2f7e786000-7f2f7e787000 rw-p 0000b000 fc:00 128588 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f2f7e787000-7f2f7e79e000 r-xp 00000000 fc:00 128601 /lib/x86_64-linux-gnu/libnsl-2.15.so
7f2f7e79e000-7f2f7e99d000 ---p 00017000 fc:00 128601 /lib/x86_64-linux-gnu/libnsl-2.15.so
7f2f7e99d000-7f2f7e99e000 r--p 00016000 fc:00 128601 /lib/x86_64-linux-gnu/libnsl-2.15.so
7f2f7e99e000-7f2f7e99f000 rw-p 00017000 fc:00 128601 /lib/x86_64-linux-gnu/libnsl-2.15.so
7f2f7e99f000-7f2f7e9a1000 rw-p 00000000 00:00 0
7f2f7e9a1000-7f2f7e9a9000 r-xp 00000000 fc:00 128593 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f2f7e9a9000-7f2f7eba8000 ---p 00008000 fc:00 128593 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f2f7eba8000-7f2f7eba9000 r--p 00007000 fc:00 128593 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f2f7eba9000-7f2f7ebaa000 rw-p 00008000 fc:00 128593 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f2f7ebaa000-7f2f7ec72000 rw-p 00000000 00:00 0
7f2f7ed24000-7f2f7ed3a000 r--p 00000000 fc:00 12643 /usr/share/fonts/type1/gsfonts/n022024l.pfb
7f2f7ed3a000-7f2f7ed9b000 r-xp 00000000 fc:00 11704 /usr/lib/x86_64-linux-gnu/libtiff.so.4.3.4
7f2f7ed9b000-7f2f7ef9a000 ---p 00061000 fc:00 11704 /usr/lib/x86_64-linux-gnu/libtiff.so.4.3.4
7f2f7ef9a000-7f2f7ef9c000 r--p 00060000 fc:00 11704 /usr/lib/x86_64-linux-gnu/libtiff.so.4.3.4
7f2f7ef9c000-7f2f7ef9d000 rw-p 00062000 fc:00 11704 /usr/lib/x86_64-linux-gnu/libtiff.so.4.3.4
7f2f7ef9d000-7f2f7efa4000 r-xp 00000000 fc:00 175059 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f2f7efa4000-7f2f7f1a3000 ---p 00007000 fc:00 175059 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f2f7f1a3000-7f2f7f1a4000 r--p 00006000 fc:00 175059 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f2f7f1a4000-7f2f7f1a5000 rw-p 00007000 fc:00 175059 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
7f2f7f1a5000-7f2f7f1aa000 r-xp 00000000 fc:00 175056 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtga.so
7f2f7f1aa000-7f2f7f3a9000 ---p 00005000 fc:00 175056 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtga.so
7f2f7f3a9000-7f2f7f3aa000 r--p 00004000 fc:00 175056 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtga.so
7f2f7f3aa000-7f2f7f3ab000 rw-p 00005000 fc:00 175056 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtga.so
7f2f7f3ab000-7f2f7f400000 r-xp 00000000 fc:00 97518 /usr/lib/x86_64-linux-gnu/libQtSvg.so.4.8.1
7f2f7f400000-7f2f7f600000 ---p 00055000 fc:00 97518 /usr/lib/x86_64-linux-gnu/libQtSvg.so.4.8.1
7f2f7f600000-7f2f7f602000 r--p 00055000 fc:00 97518 /usr/lib/x86_64-linux-gnu/libQtSvg.so.4.8.1
7f2f7f602000-7f2f7f603000 rw-p 00057000 fc:00 97518 /usr/lib/x86_64-linux-gnu/libQtSvg.so.4.8.1
7f2f7f603000-7f2f7f608000 r-xp 00000000 fc:00 175086 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f2f7f608000-7f2f7f807000 ---p 00005000 fc:00 175086 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f2f7f807000-7f2f7f808000 r--p 00004000 fc:00 175086 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f2f7f808000-7f2f7f809000 rw-p 00005000 fc:00 175086 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so
7f2f7f809000-7f2f7f83c000 r-xp 00000000 fc:00 15889 /usr/lib/x86_64-linux-gnu/liblcms.so.1.0.19
7f2f7f83c000-7f2f7fa3c000 ---p 00033000 fc:00 15889 /usr/lib/x86_64-linux-gnu/liblcms.so.1.0.19
7f2f7fa3c000-7f2f7fa3d000 r--p 00033000 fc:00 15889 /usr/lib/x86_64-linux-gnu/liblcms.so.1.0.19
7f2f7fa3d000-7f2f7fa3e000 rw-p 00034000 fc:00 15889 /usr/lib/x86_64-linux-gnu/liblcms.so.1.0.19
7f2f7fa3e000-7f2f7fa40000 rw-p 00000000 00:00 0
7f2f7fa40000-7f2f7fac3000 r-xp 00000000 fc:00 15908 /usr/lib/x86_64-linux-gnu/libmng.so.1.1.0.10
7f2f7fac3000-7f2f7fcc3000 ---p 00083000 fc:00 15908 /usr/lib/x86_64-linux-gnu/libmng.so.1.1.0.10
7f2f7fcc3000-7f2f7fcc6000 r--p 00083000 fc:00 15908 /usr/lib/x86_64-linux-gnu/libmng.so.1.1.0.10
7f2f7fcc6000-7f2f7fcc8000 rw-p 00086000 fc:00 15908 /usr/lib/x86_64-linux-gnu/libmng.so.1.1.0.10
7f2f7fcc8000-7f2f7fccd000 r-xp 00000000 fc:00 175058 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f2f7fccd000-7f2f7fecd000 ---p 00005000 fc:00 175058 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f2f7fecd000-7f2f7fece000 r--p 00005000 fc:00 175058 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f2f7fece000-7f2f7fecf000 rw-p 00006000 fc:00 175058 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so
7f2f7fecf000-7f2f7ff0d000 r-xp 00000000 fc:00 11546 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
7f2f7ff0d000-7f2f8010d000 ---p 0003e000 fc:00 11546 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
7f2f8010d000-7f2f8010e000 r--p 0003e000 fc:00 11546 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
7f2f8010e000-7f2f8010f000 rw-p 0003f000 fc:00 11546 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
7f2f8010f000-7f2f8011f000 rw-p 00000000 00:00 0
7f2f80131000-7f2f80138000 r-xp 00000000 fc:00 175057 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f2f80138000-7f2f80337000 ---p 00007000 fc:00 175057 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f2f80337000-7f2f80338000 r--p 00006000 fc:00 175057 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f2f80338000-7f2f80339000 rw-p 00007000 fc:00 175057 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so
7f2f80339000-7f2f80340000 r-xp 00000000 fc:00 175061 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f2f80340000-7f2f8053f000 ---p 00007000 fc:00 175061 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so
7f2f8053f000-7f2f80540000 r--p 00006000 fc:00 175061 /usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.soAborted (core dumped)
I tried to run visualize the cavity case and this was my terminal output.
I really have no idea what's happening...
wyldckat March 25, 2013 16:53
Hi aevub,
OK, a few questions:
  1. Which installation instructions did you follow?
  2. Did you build from source?
  3. If your display is ":10", are you using a VNC connection?
  4. Did you install the mesa drivers?
Best regards,
Bruno
aevub March 27, 2013 04:12
I followed the one from chalmers but changed the directories to /usr/local
Openfoam 2.1.X and 1.6 ext worked perfectly next to each other, but only paraview/parafoam doesn't.
I then tried to install the package, but that didn't work either.
Tried from source, tried from package
No clue what you mean ;)
Yups.
BUT...!
I was working on a server with ubuntu 12.04. I think he had problems locating the graphics driver. Normally, mesa should have helped that, but it didn't.
I thus installed ubuntu 12.04 client on my laptop, he still didn't see my graphics driver.
I then installed 10.04 (I still had that lying around) and upgraded this version to ubuntu 12.10, installed the mesa files.. and as a miracle, ubuntu finally recognized the graphics drivers..
I recompiled the whole lot of OpenFOAM. The paraview 3.13.2 in the thirdparty still does not work,
(errror:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
which I did without result (maybe because I now use 12.10?))
But the paraview package 3.14.1 does work, so I'll be using that one then, without parafoam.
So..
Is it possible that there is some kind of bug in the ubuntu 12.04 LTS version?
Because I still don't have paraview on my server...
wyldckat March 27, 2013 17:30
If I'm not mistaken, Ubuntu 12.04 has got ParaView 3.14.1 in its repositories. Therefore, you try the following steps:
  1. Install the ParaView version provided by Ubuntu - run as root:
    apt-get install paraview
  2. Add the following line to the end of your "~/.bashrc" file (on your own account, not in root mode):
    alias paraFoam='paraFoam -builtin'
  3. Start a new terminal and give it a try with one of the tutorials.
As for VNC, here's a good source of information about it: http://en.wikipedia.org/wiki/Virtual_Network_Computing ;)
