[General] Opening .dat and .cas files in Paraview and viewing streamlines |
August 5, 2015, 16:48 |
Hassan Iftekhar
Rep Power: 11 |
How can I open fluent output files .dat and .cas files in paraview? Furthermore how can I view streamlines around the object under study.. Your help is much appreciated. |
August 7, 2015, 00:09 |
Anonymous
Rep Power: 12 |
Its much easier to use export>solution_data>encase_gold in fluent. Once you select data that need to exported a .encas file will be created along with the data you requested.
Just change the .encas to .case and read directly in to Paraview. |
August 7, 2015, 11:18 |
Streamlines
Hassan Iftekhar
Rep Power: 11 |
Thanks that worked for me. Moreover, how can I slice a plane and view streamlines or vector plots on that plane.
August 7, 2015, 22:53 |
Anonymous
Rep Power: 12 |
Slicing option is available which is pretty straight forward. For Stream lines also direct option in tool bar is available but it is a bit different from Fluent. Vectors are called Glyphs here.
fluent, paraview, streamlines |
