Home > Forums > OpenFOAM Paraview & paraFoam
Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12
Like Tree9Likes
Old   August 18, 2013, 17:42
immortality's Avatar
Ehsan
immortality is on a distinguished road
Bravo Bruno!
it works fine now.but I have trouble with saving it.when I save state and exit from paraView and then start it and use load state another file with the same name appear in biltin part in paraView and filds became disappear! and doesn't work correctly.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 18, 2013, 17:52
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Before opening ParaView, run:
paraFoam -touch
Last edited by wyldckat; August 19, 2013 at 09:49. Reason: it's "-touch", not "-builtin"
Old   August 19, 2013, 08:33
Ehsan
Hi Bruno
this type of error occurs again when save and load state:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481
vtkOpenFOAMReaderPrivate (0x2cff1b0): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/T: Expected number, string or (, found Temperature
vtkOpenFOAMReaderPrivate (0x2cff1b0): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/U: Expected number, string or (, found Velocity
vtkOpenFOAMReaderPrivate (0x2cff1b0): Error reading line 20 of /home/ehsan/Desktop/WR_3/0/k: Expected number, string or (, found turbulentK
vtkOpenFOAMReaderPrivate (0x2cff1b0): Error reading line 20 of /home/ehsan/Desktop/WR_3/0/omega: Expected number, string or (, found turbulentOmega
vtkOpenFOAMReaderPrivate (0x2cff1b0): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/p: Expected number, string or (, found Pressure
Traceback (most recent call last):
  File "<string>", line 42, in <module>
  File "<string>", line 7, in tick
AttributeError: 'NoneType' object has no attribute 'UpdatePipeline'
vtkOpenFOAMReaderPrivate (0x245ee40): Error reading line 33568 of /home/ehsan/Desktop/WR_3/5e-06/ddt0(rhoU).gz: Inflation failed:
Old   August 19, 2013, 10:10
Bruno Santos
Hi Ehsan,
Sorry, apparently last night I was a bit tired already and I didn't notice that I wrote "-builtin" instead of "-touch". I've corrected the previous post.
OK, to avoid future problems with the state files, I suggest that you follow this procedure:
  1. On each one of your cases, create 2 dummy files, one for each type of plug-in:
    touch case.foam
    touch case.OpenFOAM
    The name itself doesn't matter much, what matters is the extension (".foam" or ".OpenFOAM") and that the name is the same for all of your cases.
  2. Instead of running paraFoam, run paraview:
    paraview
  3. Now, open the file you want to use in ParaView, either "case.foam" or "case.OpenFOAM".
  4. Then configure things to your needs, such as: which fields to load, scales, legends, colours and so on.
  5. Now, before saving the state file, make sure that you are at the time instance "0".
  6. Save the state file inside the case folder.
  7. You can now repeat the same for the other file, namely "case.foam" or "case.OpenFOAM".
  8. Once you have the desired state files well saved, you should always use the paraview command to start ParaView and to have the "case.*" and state files inside each case.
    • Keep in mind that when a state file is opened, it's hard-coded to open the case file located at the full path, not the relative path. The reason why I say that you should save the state file inside the respective case, is to make it a bit easier to locate the "case.*" files.
    • With this methodology, you should be able to re-use the same state file and "case.*" files on any case.
Best regards,
Bruno
immortality likes this.
Old   September 14, 2013, 05:33
Ehsan
why when paraview is making images for animation,it abruptly closes itself and making animations discontinues?
Old   September 14, 2013, 06:18
Ehsan
what does this error(warning) means?
Old   September 14, 2013, 06:35
Ehsan
when above error is shown,the maximums in images are saved wrong,
in attachments KE.0116.jpg is saved by the python script and 116 is screenshot.
then troubles are these:
1) paraFoam doesn't act good with extremes of variables,means legends are in 0,1 region
2)because of 1,I open cases by paraview -dr as dear Bruno mentioned somewhere,
3)in one case,when it reaches to a middle time,paraview suddenly closes (during saving animation),
4)in other case,paraview doesn't save correct values in ranges for maximum in saving animation
Old   September 14, 2013, 07:54
Bruno Santos
Hi Ehsan,
That seems to be related to this: Paraview 3.12 memory allocation problem while saving animation
Use the command top in a new terminal, to confirm if the memory occupied by ParaView keeps rising. Or use "System Tools -> System Monitor" instead of top.
I guess it's because you didn't configure properly the script used for updating the ranges. But since you didn't give a proper description of what you've done to get that error, I can only guess.
2) You probably saw it here: paraview 3.8 auto rescale doesn't work
3) Explained in the first paragraph of this post I'm writing.
4) Uh... the answer after the 2nd quote?
Best regards,
Bruno
Old   September 14, 2013, 11:46
Ehsan
it only occupies 50% of memory but closes abruptly.
I did what you had told
forgot to attach system Monitor.
Old   September 14, 2013, 12:09
Bruno Santos
But how exactly did the memory occupancy by ParaView evolve along the animation?
And no, you didn't attach the image of the System Monitor
Old   September 14, 2013, 12:39
Ehsan
Old   September 14, 2013, 12:46
Ehsan
Bruno something occupies the memory when paraview's are closed!
how can find out what it is?
it hardly attaches.
Old   September 14, 2013, 12:54
Bruno Santos
Have you looked in the "Processes" tab on the "System Monitor"?
Old   September 14, 2013, 16:24
Ehsan
a corrupted pidgin run had occupied the memory.
Old   September 15, 2013, 04:18
Ehsan
dear Bruno Hi,
I added this code according to what you said and I had done before also,
from paraview.simple import *
def start_cue(self): pass
def tick(self):
    source = FindSource("WR_4.OpenFOAM")
    #This works on ParaView 4.0.1
    source.UpdatePipeline(self.GetAnimationTime())
    #This works on ParaView 3.12.0
    #source.UpdatePipeline(GetAnimationScene().TimeKeeper.Time)
    #The array and number of components
    #arrayName = "p"
    #arrayComponents = 1
    #component = -1
    #options for component: -1, 0, 1 and 2 => Mag, X, Y, Z
    # If it's a scalar field
    arrayName = "p"
    arrayComponents = 1
    component = 0
    #Get the look-up table for this array
    lookupTable = GetLookupTableForArray(arrayName, arrayComponents)
    #get the access to the cellData or pointData
    #data = source.GetCellDataInformation()
    data = source.GetPointDataInformation()
    #get the array and the respective min-max
    array = data.GetArray(arrayName)
    dataRange = array.GetRange(component)
    lookupTable.LockScalarRange = 1
    #Now let's hack in the range values
    lookupTable.RGBPoints[0] = dataRange[0] #min
    lookupTable.RGBPoints[4] = dataRange[1] #max
def end_cue(self): pass
but this is the error:
  File "<string>", line 47, in <module>
  File "<string>", line 9, in tick
you know that I now use 4.0.1 version,is there any other changes other than what you mentioned in post #6 I have to do to solve the issue?
Old   September 15, 2013, 05:02
Bruno Santos
Hi Ehsan,
Is the case file actually named "WR_4.OpenFOAM"? Because that error message implies that it is not.
Best regards,
Bruno
Old   September 15, 2013, 06:03
Ehsan
no its name is case.foam,I'm mixed up with names!
is the folder name important too?
I have to make a file with name: case.foam and open it after running "paraFoam4"?
Old   September 15, 2013, 06:10
Bruno Santos
The name and folder are not relevant to this filter. All that matters is the name you gave to it in the "Pipeline Browser" (yes, you can rename the entries there as well!).
This is because this instruction:
searches the items on said "Pipeline Browser" for the name indicated.
Old   September 15, 2013, 06:32
Ehsan
Bruno I made a file named case.foam in the case folder and used paraFoam4 command as you said me,copy the python code and take animations but the maximums are not correct,they don't match to real local maximum values and another issue is that again " Automatic Color scaling" doesn't work and scale bar doesn't change
Old   September 15, 2013, 06:54
Ehsan
Bruno I closed that and open a new paraview and rescaling problem is resolved,I worry if I add the python code it occurs again! it was working fine before,why it has became so?
paraview, rescale to data range
Thread Tools
Trackbacks are On
fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 12 May 2, 2013 10:52
data range problem bptsj ParaView 1 October 5, 2012 10:35
Automatic Data Export (ascii format) A Kourm FLUENT 3 January 21, 2009 08:36
Automatic range in paraview animations arno OpenFOAM Paraview & paraFoam 1 August 29, 2006 04:00
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
