Home > Forums > OpenFOAM Paraview & paraFoam
touch cavityFine/cavityFine.OpenFOAM PROBLEM!
Old   May 30, 2013, 18:07
Default touch cavityFine/cavityFine.OpenFOAM PROBLEM!
Amir
Amir1 is on a distinguished road
Hi guys,
I m trying to run the cavityFine on paraFoam based on the cavity problem in the user manual.
I did make the cavityFine file and I did the mapFields. Now I want to open up two files (cavity and cavityFine) with paraView but typing the following commamnd doesnt do anything:
Any suggestions or comments?
Thanks
Amir1 is offline   Reply With Quote
Old   June 8, 2013, 16:17
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Amir,
If the command does not give you any errors, then it worked with success. You can check if the file was created by running:
ls -l cavityFine/cavityFine.OpenFOAM
If it shows you that the file does exist, then open it in the ParaView window you already have open from the first "cavity" case.
Best regards,
Bruno
Old   June 8, 2013, 22:01
Amir
Thanks so much.
I will try do check it out and will let you know.
Cheers!
Amir
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
paraFoam touch problem DiegoNaval OpenFOAM 0 August 4, 2011 05:05
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
