Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaFoam ...
Old   June 8, 2013, 06:16
Default ParaFoam ...
rajcfd is on a distinguished road
I am running a heat transfer problem. I have set up the case but when I am opening the case in paraFoam it is showing following problem:-
stripInvalid() called for invalid fileName T~
for debug level (=2) >1 this is considered fatal
Aborted
What is this error and how can it be rectified?
rajcfd is offline   Reply With Quote
Old   June 8, 2013, 16:40
Retired Super Moderator
Bruno Santos
Greetings rajcfd and welcome to the forum!
It's simple: you edited the file "T" with a text editor that creates backups of the files when saving. Therefore, you have a file named "T~" somewhere next to the "T" file.
Then OpenFOAM's reader for ParaView is complaining about this "T~" file, because of the tilde "~" character.
The solution is to remove the file "T~" and the problem will be solved.
Check the options in your text editor to not save backups of files.
And if you do want to keep track of the changes you make to the case, I suggest that you study and use a source revision management software, such as Git or Mercurial
Best regards,
Bruno
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 08:09
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 17:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
[OpenFOAM] Parafoam basic questions qtian ParaView 0 July 20, 2007 11:52
