Home > Forums > OpenFOAM Paraview & paraFoam
how to add fields in list as default?
Old   June 28, 2013, 04:31
Default how to add fields in list as default?
immortality's Avatar
Ehsan
immortality is on a distinguished road
when we open a case in paraview p and U fields are in field list without need to select them separately,how can i add T field to the list so that it be automatically available whenever i open a case in paraview?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 28, 2013, 15:59
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Hi Ehsan,
This is one of those situations where there is the simple way and the complicated way
The simple way is to simply run:
paraFoam -builtin
This will tell paraFoam to use the extension ".foam" in ParaView, which means that the internal reader will be used to open the case. The controls are somewhat different, but at least all fields are loaded by default.
The complicated way requires hacking the source code:
  1. Edit the file given by the following command:
    echo "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/vtkPV3FoamUpdateInfoFields.H"
  2. Find this block of code:
            enabledEntries.setSize(2);
            enabledEntries[0] = "p";
            enabledEntries[1] = "U";
  3. Change it to this:
            enabledEntries.setSize(3);
            enabledEntries[2] = "T";
  4. Save and close the file.
  5. Rebuild OpenFOAM's plug-ins for ParaView:
    cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
    ./Allwclean
    ./Allwmake
Two notes:
  • This hack can lead to a crash when you try to open a case that does not have the "T" field.
  • If you have got the Deb or RPM version of OpenFOAM installed, then you need to edit and rebuild the plug-ins with root powers.
Best regards,
Bruno
Old   June 28, 2013, 16:23
Ehsan
Hi Bruno
How to edit the file with root power?
Old   June 28, 2013, 16:46
Bruno Santos
Remember this thread: ok compile but not find the solver !
Back in April it looked like you knew how to edit files as root...
Old   June 28, 2013, 16:51
Ehsan
Originally Posted by immortality View Post
Hi Bruno
I found the file you said but it can't be saved.it has only save as.
Old   June 28, 2013, 17:04
Bruno Santos
OK, then maybe it's better to think this the other way around:
  1. Change the permissions on the file, by running this command:
    sudo chmod og+w "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/vtkPV3FoamUpdateInfoFields.H"
    This will allow you to write to the file.
  2. Modify the file with the text editor you were using and then save the file. If it gives you an error about not being to save a backup file, it doesn't matter much, because we don't need a backup.
  3. Change the permissions on the file once again, by running:
    sudo chmod og-w  "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/vtkPV3FoamUpdateInfoFields.H"
Then for building, run:
sudo su -c ". $WM_PROJECT_DIR/etc/bashrc ; ./Allwclean; ./Allwmake"
Old   June 28, 2013, 17:09
Ehsan
when I click on "save anyway" it doesn't take action and "don't save" button turns red again and again!
Old   June 28, 2013, 17:12
Bruno Santos
Then try to change the permissions to the whole folder:
sudo chmod -R og+w "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/"
Then after saving, undo with:
sudo chmod -R og-w "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/"
Last edited by wyldckat; June 28, 2013 at 17:32. Reason: forgot the closing quote symbol :(
Old   June 28, 2013, 17:25
Ehsan
ehsan@Ehsan-com:~$ sudo chmod -R og+w "$FOAM_UTILITIES/postProcessing/graphics/PV3Readers/PV3FoamReader/vtkPV3Foam/
Bruno the cursor blinks!and it doesn't affect!
Old   June 28, 2013, 17:33
Bruno Santos
Sorry, I completely forgot about the closing quote character. I've updated the previous post with the correct code.
Old   June 28, 2013, 17:49
Ehsan
thanks a lot Bruno
It works fine now.T field is added to the list automatically.I always prefer to go a long and maybe hard way at first but be relaxed later!
how do you know all these things in different areas?!
how many years are you working on your skills?
Thread Tools
Trackbacks are On
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
Can not add a new user defined visualization parameter in Cut plot! george85 FloEFD, FloWorks & FloTHERM 5 November 9, 2011 14:33
Need help in Scheme Programming - Mulltiplying list elements ydan87 Fluent UDF and Scheme Programming 2 November 9, 2011 01:05
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
