ParaView crashes when I press the Apply button
Hi
I have a strange problem with Paraview. I have installed the latest OpenFOAM and Paraview. But when I want to open Paraview (to see the grid or the results), when I press "apply" to show the boundaries, it is suddenly closed ans crashes! :-o Does anybody know what is wrong? what shall I do? Thank you very much for your help. |
Greetings mohammad81,
Which version of paraview you install? Make Sure whether its 32 bit or 64 bit or otherwise uninstall and try one more time or May be Mesh size (grid) is more, you can try with less grid. |
Hi Kumar
Thanks for the reply. I installed the latest version Paraview 3.12.0 exactly as instructed from http://www.openfoam.org/download/ubuntu.php This sometimes happens for some cases. For example, for cavity problem, it is fine, but when I want to open my own created case, it crashes. I created a mesh by Gmsh and converted successfully in OpenFOAM by gmshToFoam, but Paraview can not open it and crashes! Any idea about this problem? Thanks a lot. |
Hai,
Are you using laptop or computer, I thought due to grid size only, anyhow better check some other post you can get better idea. |
Greetings to all!
@Mohammad:
Bruno |
Thank you very much guys, specially Bruno. Very helpful.
