Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] View points in VTK File
Old   July 18, 2013, 09:47
Default View points in VTK File
Cay Myers
baila12 is on a distinguished road
After running a case using the LTSReactingParcelFoam lagrangian solver, I ran the foamToVTK command which generated a VTK file of the reacting cloud. I cannot figure out how to view the source code of this file as it is such an obscure file format. What I am trying to do is extract the xyz coordinates of each point in the reacting cloud. If this is possible in paraview, I have not figured out how to do it, and no program that I can find (other than installing the visualization toolkit) will open the file.
Any help would be appreciated!
baila12 is offline   Reply With Quote
Old   July 21, 2013, 12:12
Retired Super Moderator
Bruno Santos
Greetings Cay,
In ParaView, menu "File -> Save Data", it allows you to save the point or cell data, for example to a CSV file. This of course is assuming that the correct entry is selected in the "Pipeline Browser".
For reference for other forum readers, instructions on how to visualize these points in 3D is shown here: http://openfoamwiki.net/index.php/Ma...gian_particles
Best regards,
Bruno
Old   July 22, 2013, 08:16
Cay Myers
Thank you for your reply! This solved my problem.
paraview, point determination, vtk files
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
