Home > Forums > OpenFOAM Paraview & paraFoam
Compile Error paraFOAM
Like Tree1Likes
  • 1 Post By alexeym
Old   July 19, 2013, 08:06
Default Compile Error paraFOAM
Stefan Hildenbrand
shildenbrand is on a distinguished road
Dear FOAMers,
I downloaded Paraview 4.0.1 and am trying to use it instead of paraview 3.12 which is shipped with OF 2.2.1.
I was able to compile paraview 4.0.1 - and it works.
I have, however, problems when compiling the PV3 readers - see below.
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file vtkPV3blockMesh.C
Making dependency list for source file vtkPV3blockMeshConvert.C
Making dependency list for source file vtkPV3blockMeshUtils.C
SOURCE=vtkPV3blockMesh.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.2.1/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.2.1/src/mesh/blockMesh/lnInclude -I/opt/OpenFOAM/ThirdParty-2.2.1/platforms/linux64Gcc/paraview-4.0.1/include/paraview-4.0 -I../../vtkPV3Readers/lnInclude -I../PV3blockMeshReader -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.2.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/vtkPV3blockMesh.o
In file included from vtkPV3blockMesh.C:27:0:
../PV3blockMeshReader/vtkPV3blockMeshReader.h:60:1: Fehler: expected initializer before : token
make: *** [Make/linux64GccDPOpt/vtkPV3blockMesh.o] Fehler 1
A similar error occurs later:
../PV3FoamReader/vtkPV3FoamReader.h:62:1: Fehler: expected initializer before : token
I found a thread with the same problem but with no solution (it was with an old version of both, though)
Any hints?
Thanks,
Stefan
shildenbrand is offline   Reply With Quote
Old   July 19, 2013, 08:19
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
Actually Paraview 4.0.1 has built-in OF reader. So you can use 'paraFoam -builtin' command. In my case I've edited two lines in paraFoam script to make -builtin switch unnecessary:
# reader extension
extension=foam # OpenFOAM
requirePV=0
chrisb2244 likes this.
alexeym is offline   Reply With Quote
Old   July 19, 2013, 09:10
Stefan Hildenbrand
Thanks - that was easy.
I guess PV3 reader comes from Paraview 3.xx ?
Old   July 19, 2013, 09:29
Alexey Matveichev
Don't know. It can be either FROM PV 3.x or FOR PV 3.x Guess PV changed API in 4.x version which resulted in error during compilation.
openfoam 2.2.x, paraview 4.0.1, pv3foamreader
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 04:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
