Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] plot particles and animation in paraview
Old   December 16, 2009, 13:51
Default plot particles and animation in paraview
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
This is not CFD (or OpenFOAM) related. but, it will be highly appreciated if someone familar with paraview can help. I cannot post question on the paraview mailing list yet. So, I thought that I will try this forum first.
I did a simple particles under magnetic field calculation using perl as following:
initially, a couple of hundreds of particles are randomly distributed inside a domain (say, Xmin, Ymin, Xmax, Ymax) using a random generator. The size of the particles are also randomly generated.
The domain is then under magnetic field, this starts to track the particles toward the magnetic source.
I have aleady calculated the particle positions as a function of time. Now, I would like to plot the particles (including the size) as function of time, ie, animation.
What format should I use so that paraview can read the dataset in?
Any tutorial on paraview on something like this (how to do animation of particles in paraview)?
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   July 26, 2013, 05:35
startingWithCFD is on a distinguished road
Hello! Sorry to bump this old thread, but have you found an answer to your problem?
Could you please provide a small example of a particle file?
Last edited by startingWithCFD; July 26, 2013 at 05:36. Reason: Added "please" :-D
startingWithCFD is offline   Reply With Quote
fluent DPM - post processing ParaView gigivmasche FLUENT 4 October 23, 2019 03:05
Can anyone help me with the animation of particle track ? pkp FLUENT 0 February 28, 2016 23:10
How to make animation of DPM/DDPM particles chaada Fluent Multiphase 1 January 27, 2016 19:41
[OpenFOAM] Particle Tracking in ParaView for Non-Lagrangian Solvers Cyberholmes ParaView 1 March 20, 2014 03:52
Loading Lagrange Particles dravimech OpenFOAM Post-Processing 0 March 8, 2013 09:18
