[OpenFOAM] error in 0 folder by defining a variable in another place |
August 13, 2013, 01:51 |
Ehsan
Rep Power: 26 |
Hi
in 0 folder I have set for instance first part of p file as: Code:
dimensions [1 -1 -2 0 0 0 0]; #include "include/initialConditions" internalField uniform $Pressure; Code:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x1d7e110): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/T: Expected number, string or (, found Temperature ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x1d7e110): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/U: Expected number, string or (, found Velocity ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x1d7e110): Error reading line 20 of /home/ehsan/Desktop/WR_3/0/k: Expected number, string or (, found turbulentK ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x1d7e110): Error reading line 20 of /home/ehsan/Desktop/WR_3/0/omega: Expected number, string or (, found turbulentOmega ERROR: In /home/opencfd/OpenFOAM/ThirdParty-dev/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x1d7e110): Error reading line 19 of /home/ehsan/Desktop/WR_3/0/p: Expected number, string or (, found Pressure
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
CFX 11.0 "Vector Variable Normal” Does not Rotate with Domain? User Surface Moving | jrl4444 | CFX | 4 | November 14, 2013 17:46 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Multi_component Vs Additional Variable | Anurag | CFX | 2 | February 4, 2005 16:45 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
