Paraview canot visualize codedFixedValue velocity
Hi Foamers:
I have a codedFixedValue boundary condition (for velocity and wall motion) at a moving wall boundary. But when I load up the case on paraview, it gives an error when trying to read the velocity and pointsMotion files. Error message looks like: " Error reading line xxx of casename/0/U: Unsupported directive { " As a result I canot load velocity files and cant generate streamlines for the simulation. Is there a way around this?? Thanks. |
I have the same problem. Did you find a solution?
Edit: You *can* delete the code block ('#{' to '#}') out of the appropriate results files, but this is a bit painful. I'm not sure what effect it has on subsequent time steps either. Is there another way to make paraview cooperate? |
Greetings to all!
A few questions
And this tutorial uses code for "0/U". Best regards, Bruno |
2) OpenFOAM 2.1.x 3) case.foam file, opened from Paraview (not paraFoam) 4) I actually get the error: Code:
Making dependency list for source file codeStreamTemplate.C Thanks Bruno! |
Hi Ken,
Unfortunately the internal reader in ParaView 3.12.0 to 4.0.1 cannot handle many of the new things that have been implemented since OpenFOAM 2.0.0. The only fail-safe measure I can suggest is to rely on foamToVTK: Code:
foamToVTK -poly Then open in ParaView the files that are in the newly created VTK folder. The other possible solution (that I haven't tested) is to build the latest plug-in that Takuya has made: http://openfoamwiki.net/index.php/Co...r_for_ParaView But this requires that you also build ParaView from source code... Best regards, Bruno |
Good to know.
If I instead launch Paraview using 'paraFoam', should it work? I am connecting remotely (pvserver). |
If the paraFoam command is opening with the file extension ".OpenFOAM" and is using OpenFOAM's own plug-in reader, then it should work. Although it won't be able to load decomposed cases.
If by any chance you want to build OpenFOAM's own plug-in for ParaView 4.0.1, see this bug report: http://www.openfoam.org/mantisbt/view.php?id=621 |
