Home > Forums > OpenFOAM Paraview & paraFoam
turbineSiting tutorial and paraview-3.98.0
Like Tree2Likes
  • 1 Post By wyldckat
Old   August 25, 2013, 13:20
Default turbineSiting tutorial and paraview-3.98.0
Stephen Bosch
pajot is on a distinguished road
After successfully running the Allrun script in the simpleFoam/turbineSiting tutorial, paraview won't play the simulation.
(Note that in the below, paraFoam is an alias to 'paraFoam -builtin'. Without '-builtin', paraFoam won't even run.)
../turbineSiting $ paraFoam
created temporary 'turbineSiting.foam'
ERROR: In /var/tmp/portage/sci-visualization/paraview-3.98.0/work/ParaView-3.98.0-src/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6535
vtkOpenFOAMReaderPrivate (0x386d430): Wrong list type for uniform field
I'm running OF 2.2.1. Although I've seen this error before, running 'paraFoam -builtin' addressed it the last time, and paraview-3.98.0 still works with my other simulation.
pajot is offline   Reply With Quote
Old   August 25, 2013, 14:50
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Stephen,
The internal ".foam" reader is allergic to the boundary condition "uniformFixedValue". Therefore, before running paraview, you'll need to run this command:
sed -i -e "s=uniformFixedValue=fixedValue=g" [0-9][0-9]*/{U,p,k,nut,epsilon}
It will replace all occurrences of "uniformFixedValue" with "fixedValue", for all of the essential field files in the time folders after "0".
The problem is that you should not use these time folders for continuing the simulation afterwards, since this hack could damage the simulation characteristics for continuing simulating. But it should not damage the results for post-processing.
edit: By the way, the same happens in ParaView 3.12.0.
Best regards,
Bruno
pajot likes this.
Old   August 26, 2013, 02:50
Stephen Bosch
Hi Bruno,
Originally Posted by wyldckat View Post
Greetings Stephen,
The internal ".foam" reader is allergic to the boundary condition "uniformFixedValue"...
So, this is a "real error", then, and not a red herring?
With that hack, the post-processing works; now I can tinker with the simulation to try and understand it.
Thanks for responding so quickly, you've always been an enormous help!
Old   September 12, 2013, 11:31
Wouter van der Meer
wouter is on a distinguished road
Hello Wyldckat,
Do you have a trick like this for binary compressed files in paralel? I have this problem with paraview3.98.0
thanks
Wouter
wouter is offline   Reply With Quote
Old   September 14, 2013, 10:19
Bruno Santos
Greetings Wouter,
Why yes, yes I do!
Although, the sed command should also work in binary and in parallel... something like:
sed -i -e "s=uniformFixedValue=fixedValue=g" processor*/[0-9][0-9]*/{U,p,k,nut,epsilon}
Anyway, the other trick is that OpenFOAM has a utility application called changeDictionary. It provides an example dictionary next to the source code: https://github.com/OpenFOAM/OpenFOAM...DictionaryDict
A quick summary "system/changeDictionaryDict" would be:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      changeDictionaryDict;
dictionaryReplacement
    "(U|p|k|nut|epsilon)"
        boundaryField
            "(your|patch|names|here)"
                type            fixedValue;
Then use it by running the utility in parallel as well, the same way you ran the solver. For more information on options:
changeDictionary -help
Best regards,
Bruno
edit: Wouter found an issue with having to run changeDictionary for multiple times. A hack to do this is provided here: changeDictionary fails with multiple times post #4
pajot likes this.
Thread Tools
Trackbacks are On
Motobike tutorial U, P etc. data not loading to ParaView. Doug68 OpenFOAM Running, Solving & CFD 4 September 3, 2016 14:08
Cavity Tutorial: ParaView starts, cannot find reader mfrain OpenFOAM Paraview & paraFoam 7 June 18, 2012 22:14
Watching the chtMultiRegionFoam tutorial in Paraview anke OpenFOAM 1 March 1, 2010 09:38
Paraview tutorial ztdep OpenFOAM Paraview & paraFoam 0 April 23, 2008 07:05
HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan OpenFOAM Paraview & paraFoam 2 February 13, 2006 08:37
