Home > Forums > OpenFOAM Paraview & paraFoam
defining more than one field in calculator
Like Tree3Likes
  • 1 Post By Bernhard
  • 1 Post By wyldckat
Old   September 3, 2013, 10:33
Default defining more than one field in calculator
immortality's Avatar
Ehsan
immortality is on a distinguished road
How can define more than only one field in calculator or by any other means?
when I define a new field it replaces to older one.
I just want to change field names to more clear ones so that I can compare the results in different cases together,for example I want to name p as p_case1 in case 1 and p_case2 in case2 so that it be distinctive in graphs I want to plot later.
any help or nice idea?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 3, 2013, 10:57
Bernhard
Bernhard is on a distinguished road
You can change the "Result Array Name" in the Calculator filter. Does that work for you?
Bernhard is offline   Reply With Quote
Old   September 3, 2013, 11:25
Ehsan
Hi Bernhard
yes that works but only for one field,I want to define another field like T_KE_lastCycle in return of T too.
Old   September 3, 2013, 11:31
Bernhard
Add another calculator.
immortality likes this.
Old   September 3, 2013, 12:31
Ehsan
is it possible to make new fields from current fields by any of postProcessing utilities?
edit: when I open VTK file of fields it has incorrect result in extreme x,mean 0 and .069 that shows very low numbers near zero,may there is a mistake in creating and save VTK file on a line?it should be saved as cell or point values or any other mistake?
edit 2: the range of incorrect T is clear in this wider view (3rd picture)
edit 3: VTK file are these if you want to test yourself. (the tar.gz files)
Old   September 3, 2013, 17:13
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@Ehsan: From what I can deduce, there seems to have been an interpolation problem at the extremities of the line that was used for the "0.007464_.vtk" data.
Since you did not detail the complete list of steps you've followed for generating this data, there is nothing more I can say about this.
Good luck!
Bruno
Old   September 3, 2013, 17:19
Ehsan
I defined another VTK and it resolved! its good but I want to know the reason,maybe I have done something that I don't know!
the attached image is the result,thats so good that two graphas are the same nearly almost!too good results is a trouble itself!
Hi Bruno!
I saw your post after I sent above post!
but I followed these steps like previous one:
  1. open paraFoam
  2. after selecting the proper time snapshot,use "plot on line"
  3. File-> save data->selecting of "Legacy vtk file" format and save
I think that's all! (and now I managed to do what I had learnt to make a list in posts )
Old   September 3, 2013, 17:37
Bruno Santos
How exactly did you define the line?
Old   September 3, 2013, 18:08
Ehsan
yes it could be the cause.probably I didn't select the x direction and it remained on diagonal direction that it was by default(it was near to do this mistake sometimes)can it make that problem?
Old   September 4, 2013, 16:05
Bruno Santos
You didn't answer my question. Therefore, anything is possible...
Old   September 4, 2013, 16:37
Ehsan
Hi Bruno
well...I simply selected "X axis" in object inspector properties.
Old   September 4, 2013, 16:57
Bruno Santos
OK... well, then the diagnosis only explains the problem on one side.
If the line was diagonal, then on one end the values would likely to not even be present. But on the other end, they should be a bit more correct... unless near the top and bottom walls, the values are so low in comparison.
You'll have to try and reproduce the same error.
But my guess is that there was a very slight change made to the positions of the extremities of the line. An error of 1.0e-7 metres would probably be more than enough.
The other possibility is if the geometry is very small, there could be some geometrical representation related errors. I vaguely remember about a situation where streamlines did not work for nano sized domains, because some of the parameters for the streamline algorithm are hard-coded for geometries of at least the millimetre range, if I'm not mistaken.
Old   September 6, 2013, 10:29
Ehsan
Hi Bruno
I found out the cause,its related to Mesh regions!
when I select the patches and walls as well as internalMesh,the values on extremes(on the patches) are shown mistake by that exess lines goes to zero ! (I don't know why )
Old   September 7, 2013, 03:45
Bruno Santos
Hi Ehsan,
Well, I had thought about that possibility that the patches were also active, but since you didn't detail about it, I ignored that possibility
There are two possibilities here:
  1. The values are the patches are indeed very low, because they can't transfer anything through them.
  2. Or the interpolation mechanism for the "Plot over Line" filter has got issues with handling data that is specified on the centre of the faces, instead of the centre of the cells.
    • Associated to this, if using "Point Data" as the source for the data to be plotted, then the problem might be because the values in the points on the patches are different from the points that originate from the internal mesh.
Best regards,
Bruno
Thread Tools
Trackbacks are On
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 05:57
Demagnetization field jan0385 ANSYS 0 April 12, 2012 09:09
chtMultiRegionFoam - exchange data between flow field and temperature phsieh2005 OpenFOAM Running, Solving & CFD 0 February 7, 2012 10:16
Porosity field in Fluent wojciech FLUENT 1 September 20, 2010 11:19
problem with internal field and nonuniform list OFU OpenFOAM Running, Solving & CFD 1 October 5, 2009 03:35
