-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Paraview 3.98 - errors when saving geometry file (http://www.cfd-online.com/Forums/openfoam-paraview/123406-paraview-3-98-errors-when-saving-geometry-file.html)
pajot September 12, 2013 04:45
When I try to save a geometry for an OpenFOAM case that includes a couple of slice filters and an STL terrain file, I get this error:
  ERROR: In /var/tmp/portage/sci-visualization/paraview-3.98.0/work/ParaView-3.98.0-src/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 816
 vtkPVCompositeDataPipeline (0x4540a60): Input for connection index 0 on input port index 0 for algorithm vtkXMLPVAnimationWriter(0x3aa61f0) is of type vtkMultiBlockDataSet, but a vtkDataSet is required.
 vtkPVCompositeDataPipeline (0x4540a60): Input for connection index 1 on input port index 0 for algorithm vtkXMLPVAnimationWriter(0x3aa61f0) is of type vtkMultiBlockDataSet, but a vtkDataSet is required.
Any ideas? It could be harmless, the geometry files do get generated...
wyldckat September 28, 2013 10:45
Greetings Stephen,
Sorry for the late reply, but the information you've provided isn't enough either :(
Therefore, a few questions:
  1. What file format are you trying to save the data/geometry to?
  2. The error message mentions animation... how exactly are you trying to save the data/geometry? Because it seems like you're trying to save all time snapshots.
  3. Are you able to reproduce this error with one of OpenFOAM's tutorials? Such as "incompressible/simpleFoam/motorBike"?
    You'll have to uncompress the file "constant/triSurface/motorBike.obj.gz" before opening it on ParaView.
Best regards,
Bruno
