Floating Object Tutorial. No fluid shown when I click on "Play"
I am learning Floating Object Tutorial. I did blockMesh ./Allrun paraFoam &. And then when I open Paraview and No fluid is shown. When I click on "Play" in paraview, only the rectangular object is moving up and down. Any friend has any idea what I should do? Thanks very much for any help :D:) Ivy |
Hi Ivy,
Quoting myself from a year ago: Quote:
Bruno |
Hi, Bruno
Thanks for always answering my question :) Hmm I guess I am really confused with this OpenFoam.. I still can just see the box and the floatingobject moving . Still no liquid show up :( Whats weird now is, after several times trying, it started to fail. When I type paraFoam, I see the paraview and then the part "floating object meshing" in the properties disappeared. And when I click "Apply", the Paraview automatically exits. What is shown on Terminal is : --> FOAM FATAL IO ERROR: size 94848 is not equal to the given value of 96000 file: /home/yinghan/OpenFOAM/yinghan-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject/0/alpha1 from line 18 to line 94888. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file lnInclude/Field.C at line 236. FOAM exiting Do you have any idea why this happens? Thanks very much :) Ivy |
1 Attachment(s)
Hi Bruno, Please ignore my previous reply :)
I delete everything and tried again. Then I can see the floating object. Just the liquid is still missing :( Attached is how it looks like~~ I ticked "IternalMesh" "FloatingObject-Patch" and "Alpha1" Thanks sooo soo much ja :) Ivy |
Hi Ivy,
OK, I guess this has reached the "Frequently Asked Question" stature, so I've added information on this here: http://openfoamwiki.net/index.php/FA...iphase_results The page with the actual instructions is now here: http://openfoamwiki.net/index.php/Ho...iphase_results Best regards, Bruno |
Hi Bruno,
Thanks very much :))) I started to get what it supposed to look like :) Thank very much~~ Hmm but why the fluid only shows up when I change from choosing "p" to "p-rgh" ? I googled that P-rgh means dynamic pressure. Hmm sorry for all the kind of naive question ha >< Thanks soo soo much~ Best Regards, Ivy |
Hi, Bruno
I think I figured out. Now I realized that the questions asked below is quite not related to problem I encountered earlier haha. Thanks very much again :) Ivy Quote:
