October 18, 2013, 10:12 |
Mapping in ParaView
Stephane
Rep Power: 12 |
Dear all
I would like to tranfer pressure distribution from CFD meshing to FE meshing. I used Resample command but I don't have the expected distribution? Do you know a specific methodology to do that? Thanks |
October 19, 2013, 04:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Stephane,
If you can provide a simple example of the mesh with CFD data and the mesh without any data, I can give it a try. Best regards, Bruno
October 21, 2013, 03:03 |
Stephane
Rep Power: 12 |
Thank you for your answer Bruno!
Please send me your email adress in a private message to provide you a example. Stéphane |
October 26, 2013, 10:39 |
Bruno Santos
Rep Power: 128 |
Greetings Stéphane,
Since I ended up not giving you my email address and you didn't give me a link to a Dropbox file or similar, and because of a question asked in this post: http://www.cfd-online.com/Forums/ope...tml#post458475 post #24, here's what I've done to create a similar situation:
Best regards, Bruno
October 26, 2013, 15:36 |
Stephane
Rep Power: 12 |
Dear Bruno,
Thank you for your answer and test. My problem is the same, data are not at cell and I have the following problem: see picture image2.jpg I don't understand why I have a red line on the back face of the half cylinder. Pressure should be constant. I use commande Point Data to Cell data after resample command. If you have an idea? BR, Stéphane |
October 26, 2013, 16:01 |
Bruno Santos
Rep Power: 128 |
Hi Stéphane,
I think the problem is that a coarser mesh for the re-sampling isn't properly handled by ParaView, as shown in the attached image: on the left is the original case and on the right is a coarser surface mesh. I'll try to find some way of controlling how the interpolation is conducted, but it will have to be done with a "Programmable Filter". Best regards, Bruno
October 26, 2013, 17:11 |
Bruno Santos
Rep Power: 128 |
Hi Stéphane,
If I did my research correctly, it looks like the interpolation is not configurable, even through code. This is because the VTK filter "vtkProbeFilter" is not configurable: http://www.vtk.org/doc/release/5.8/html/a01586.html So, the way I see it, you should use surface meshes with similar resolution, in order to minimize the differences that occurs during interpolation. Best regards, Bruno
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 13:24 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
