Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Problem with spaces in paraFoam execution
Old   November 7, 2013, 04:00
Question Problem with spaces in paraFoam execution
Christian Butcher
chrisb2244 is on a distinguished road
I'm running a parallel ParaView 4.0.1 pre-built binary download using the multicore option that the settings in paraview offers. I'm also running OpenFOAM-2.2.2 and have made a couple of changes to the paraFoam file so that I can match these two up hopefully easily instead of using all of the ThirdParty.tar.gz files available with OpenFOAM.
The changes I've made are
extension=foam
requirePV=0
(since I haven't built the PV modules, as they want lots more config of paraview files in a collection of folders/a layout which I don't have - I'm not sure if this is my problem but I think not)
When I go to a case directory (I'm using the cavity tutorial for simplicity) and type paraFoam, I get
$ paraFoam
created temporary 'cavity.foam'
AutoMPI: SUCCESS: command is:
 "/home/christian/Downloads/ParaView-4.0.1-Linux-64bit/lib/paraview-4.0/mpiexec" "-np" "6" "/home/christian/Downloads/ParaView-4.0.1-Linux-64bit/lib/paraview-4.0/pvserver" "--server-port=54130"
AutoMPI: starting process server
-------------- server output --------------
Waiting for client...
AutoMPI: server successfully started.
Cannot open data file " cavity.foam "
If I manually type "touch cavity.foam" and then "paraview" and navigate to the file, all is well. However, as can be seen here (I think) when I use paraFoam it tries to open " cavity.foam " with spaces on either side, which is I assume why paraview complains that
it "Cannot open data file " cavity.foam ""
I looked through the paraFoam file, but can find no spaces enclosed within quotation marks that would need to not be there.
What am I missing? And is it the spaces that are the problem?
Thank you in advance
chrisb2244 is offline   Reply With Quote
Old   November 9, 2013, 15:06
Retired Super Moderator
Bruno Santos
Greetings Christian,
Interesting bug! Unfortunately those spaces are a misleading error message.
The actual problem is that the file "cavity.foam" is not being found by ParaView's pvserver, because the automatic parallel mechanism is launching the executable from its own folder, namely at:
And in that folder, there is no such "cavity.foam" file
I also have ParaView 4.0.1 handy, using an alias... which I'll write about in a bit. In the meantime, the solution is to give the full path to the file, e.g.:
paraview --data=$PWD/case.foam
And yes, "$PWD" is a valid environment variable:
As for the alias I use, I have this in my "~/.bashrc" file:
alias paraFoam4='(. $WM_PROJECT_DIR/etc/config/unset.sh; touch case.foam && $HOME/OpenFOAM/ParaView-4.0.1-Linux-64bit/bin/paraview --data=$PWD/case.foam)'
Which brings me to your modifications... you have at least 2 choices:
  • To create an alias like the one above.
  • Or to hack the paraFoam script once again and change this:
    paraview --data="$caseFile" "$@" 2>&1
    To this:
    paraview --data="$PWD/$caseFile" "$@" 2>&1
Best regards,
Bruno
openfoam 2.2.2, parafoam, paraview 4.0.1
[OpenFOAM] problem with parafoam: "Read float past end of buffer" Osman ParaView 2 March 1, 2019 07:16
[OpenFOAM] Problems running paraFoam with OpenFOAM 6: "Illegal instruction (core dumped)" nwm ParaView 1 December 22, 2018 09:47
[OpenFOAM] Post processing problem in Xfce desktop environment using paraFoam tariq ParaView 4 July 8, 2013 10:09
UDF execution problem argeus Fluent UDF and Scheme Programming 4 April 15, 2011 14:04
[OpenFOAM] Problem with paraFoam (ubuntu 9.04) peb ParaView 4 August 24, 2009 09:50
