-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Problem: Export one colum of spreadsheet (http://www.cfd-online.com/Forums/openfoam-paraview/126507-problem-export-one-colum-spreadsheet.html)
LiteCFD November 19, 2013 13:35
Hi all!
I have problem with paraview results export;
After data load i use Contour filter. It's required for drawing free surface.
Then i try to export only coordinates of contour point:
- select necessary column from spreadsheet
- File -> Save Data.
But in result csv there are all arrays (P, U, alpha, etc)
Please help. What I'm doing wrong? May be I also should use another filter?
BTW, can I copy columns directly from spreadsheet view? Ctrl+C of Edit->Copy don't work.
Thanks a lot!
tomf November 20, 2013 03:58
Usually I use some shell commands to modify the content. Something like this should work:
sed 's/,/ /g' <filename>.csv | awk '{print $1}' > column1.csv
Use $2 in the awk print part for column 2 of the csv file or if you want only columns 1 and 3, use:
sed 's/,/ /g' <filename>.csv | awk '{print $1 "," $3}' > column1and3.csv
This is more a workaround though.
Regards,
Tom
Bernhard November 20, 2013 04:02
The pipe from sed to awk seems obsolete if you could use the IFS input for awk. Anyhow:
cut -d',' -f1 <filename>.csv
would do the job too :)
arvhult March 18, 2014 10:19
I found that "file -> export scene" exports the actual selection in the spreadsheet view. It took way too much time to realize this...
This is ParaView 4.1.0 64-bit.
I share your opinion that a simple copy-paste functionality would be helpful!
Warm regards,
Carl-Magnus Arvhult
wyldckat March 21, 2014 18:03
@Carl-Magnus Arvhult: Many thanks for sharing your finding!
By the way, if anyone needs to do this in Python within ParaView: http://markmail.org/message/anlxxwlrlyacmsr6
