Home > Forums > OpenFOAM Paraview & paraFoam
Paraview problem
Old   November 27, 2013, 02:17
Default Paraview problem
CFDGuy
mehdinekooee is on a distinguished road
Hello All,
I have installed blueCFD, I can run the tutorial simulations and I know it works because I check different time steps and see the values for pressure and velocity. But when I run the Paraview it just shows an empty box where velocity and pressure is zero. Does anyone have any idea about this problem ?
Thanks.
mehdinekooee is offline   Reply With Quote
Old   November 27, 2013, 18:33
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Mehdi and welcome to the forum!
I'm assuming you've installed blueCFD-SingleCore, correct?
This is a somewhat common problem with people that are trying out OpenFOAM and ParaView/paraFoam for the first time. I'll quote myself from a couple of years ago:
Originally Posted by wyldckat View Post
It's simple:
  • You ran blockMesh, then icoFoam.
  • No errors in sight and you have the 0.1 to 0.5 time folders.
  • You ran paraFoam. ParaView opens with the case folder. You pressed the big green "Apply" button.
  • The mesh/box appears.
  • Now look at the top right half of ParaView's top toolbar and see the "Time" edit box with a spin box to the right (spin box has two triangles, one pointing up and the other down). Click on the top triangle to change the current time snapshot.
  • Then start reading here: Post-processing
To learn more about ParaView and how to use it with OpenFOAM:
Best regards,
Bruno
Old   December 1, 2013, 04:43
CFDGuy
Thanks Bruno, it helps. It works as you said.
Best regards
Thread Tools
Trackbacks are On
Problem in using paraview meballav ParaView 11 October 12, 2012 16:03
Problem with Paraview ata OpenFOAM 10 August 6, 2011 03:21
Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ OpenFOAM Paraview & paraFoam 14 August 2, 2010 18:13
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 07:39
Problem with Colors in ParaView sven OpenFOAM Paraview & paraFoam 1 May 31, 2009 08:13
