loop through vtk-files (different time step samples)
I use sample (both run-tima and as post) to create vtk files. Which creates files in the following structure surface/time/U_surfName.vtk where time = 0, 0.1, 0.2, .... Now I which to loop through these time steps what I have found is that im supposed to execute pvbatch test.py where test.py is a python script. Please help me with this script =) If possible I would like to "annote time". If I need to sample in different format sp be it Best regards Martin |
Soder,
This post from Bruno should help you get started: http://www.cfd-online.com/Forums/par...tml#post460276 I would like to do something similar. I'll try to remember to share my code when I get to it. Good luck! -Nuc |
Greetings to all!
If either one of you already has something written in Python, but it doesn't work yet, please share the code, so that I can have a look into it. I ask this simply because I don't feel like having to do everything myself ;) And if by any chance you've already solved the problem, feel free to share it :) Best regards, Bruno |
