December 30, 2013, 15:58 |
Windows Meshing and paraview
Alessandro
Rep Power: 12 |
Hi, I'm using snappyHexMesh to generate OpenFOAM mesh on windows OS. I'd like view the result of the mesh but I don't know how to use paraview to see the mesh refinements.
Any suggestion? Thank you! Ale |
December 30, 2013, 16:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Alessandro and welcome to the forum!
A few questions:
Bruno
December 30, 2013, 17:09 |
Alessandro
Rep Power: 12 |
Hi Bruno,
1. OpenFOAM for MS windows http://sourceforge.net/projects/openfoam-mswin/ 2. Just unzip the file 3. Yes, I've seen the tutorials but they refer to paraFOAM. I've installed paraView 4.1.0 for windows. I've also generate (succesfully) the mase with snappy, but I don't know how to see that in paraview. |
December 30, 2013, 17:21 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Alessandro,
That's a pretty outdated and unsupported project, but that's up to you! I usually suggest blueCFD-SingleCore, which is more recent and has a bit of support: http://code.google.com/p/bluecfd-singlecore/ - Disclaimer: I'm the guy responsible for it Either way, a good wiki page with a full list of available variants is this one: http://openfoamwiki.net/index.php/Installation/Windows Anyway, ranting aside, the solution is simple and has been discussed here on the forum in the past... let me see if I can find it... here's one: Quote:
Best regards, Bruno
December 31, 2013, 10:45 |
Alessandro
Rep Power: 12 |
Thank you Bruno,
now I'm able to see my mesh and looks great! It was generated into 2 time step. How can I use it? Can I just copy the polymesh folder of folder 2 into constant folder? |
December 31, 2013, 11:24 |
#6 | |
Bruno Santos
Rep Power: 128 |
If you were using a more recent version/port of OpenFOAM, you could use the command line option "-overwrite" in snappyHexMesh, which would tell it to always save in the latest mesh folder, i.e. "constant" in this case.
Display Modes | |
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 11:14 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[OpenFOAM] opening .stl file in paraview | gokulcfd | ParaView | 2 | March 16, 2015 15:37 |
[snappyHexMesh] Problems after snappyHexMesh with paraview | andreas0209@hotmail.com | OpenFOAM Meshing & Mesh Conversion | 10 | February 23, 2015 11:00 |
[snappyHexMesh] Meshing geometry not visible in paraView. | Nikunj.R | OpenFOAM Meshing & Mesh Conversion | 4 | October 2, 2012 15:45 |
